350 supercharger bost and de-compress
Old Oct 10, 2001 | 09:47 PM
c350b's Avatar
how much bost can you put in a stck 350 someone told me that if you put a super charger on with out decompressing the engion you will blow it up, is that true how much bost can you run befor you need to decompress, also what do you all need to decompress it
Old Oct 11, 2001 | 05:43 PM
maniacc's Avatar
On a STOCK 350 (9.3:1 compression) you can safely run 6#'s of non-intercooled boost and 10#'s of intercooled boost without any problems,(if engine is in good working condition)...
To lower the engine compression ratio, you can either change the pistons to a dished style, put on a bigger chamber cylinder head, or put in really thick head gaskets.
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
[This message has been edited by maniacc (edited October 11, 2001).]
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
88rscamar0
Sep 23, 2015 09:08 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Formula_88AE
Sep 3, 2015 01:47 PM
