Brand new engine, now I want a supercharger!
I have a brand new, installed, but never cranked ZZ4 350 in my '92 RS. I believe it has around 9.8:1 compression and the mods are in my sig.
I want to run easy 12's with a relatively quite supercharger setup. Anyone have any solid recomendations?
'92 RS-SS, ZZ4 10:1 350, Edelbrock 6085 heads, GM LT4 1.6 roller rockers, Crane 208/214 467/482 112, Edelbrock TPI, Accel 24#, Holley afpr, SLP 1-5/8" Jet-Hot headers, Catco 3" cat, Flowmaster American Thunder dual 3", Hughes 2500 stall, stock 700R4, Auburn pro-posi w/3.42, SFC, Walbro pump, ZR1 17x9" rims, BFG ZR's, Medium Quasar Blue w/white SS stripes....
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
my dad has a wieand 142 roots blower on his ZZ4 and that car F-in scoots. Runs good, just have to pull a bit of timing out to make sure it doesnt eat itself
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
If you want to keep the TPI then a roots style setup is out.
A centrifugal supercharger will bolt right up to your TPI throttle body and the inlet charge will run cooler too, which is a good thing with a compression ratio around 10:1.
If you want extremely quiet, You could try a Paxton balldrive unit but based on my own experiences I wouldn't recommend it based on reliability and heat build up issues. There are better options out there these days.
Vortechs have a better track record as far as reliability goes. their gear drive systems run cooler than Paxtons ball drive systems. The downside to gear drives are the gear noise. Vortech does make some that have quieter gear drive systems though.
Prochargers are also reliable and cool running but also a little (or a lot) noisy.
With compression that high you will want to watch carefully for detonation.
You will need to make sure that the air fuel ratio is rich enough.
You may need to reduce timing advance.
Using water injection may be a good idea.
The vortech liquid to air intercooler (Aftercooler) or Procharger air to air intercooler would reduce the chance of detonation and improve power output.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
[This message has been edited by IROCKZ4me (edited October 16, 2001).]
'86 IROC-Z Camaro
"Cogito ergo zoom"
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
Thanks Tracy! I think I'm leaning towards the ATI intercooled, and I wanted some opinions from people's experience.
I've heard that Paxton seams to have some issues. I've heard the Vortech first hand and it's very loud! I want a quite setup if it's possible...
u could try a powerdyne they are quite but the belt goes bad every 40,000. but it is just like changing a timing belt. plus they run cool. personally i like the procharger eventhough it is loud
91z28 350tpi auto runs 14.3
Vortech makes loud and quieter versions. The quieter ones have angle cut gears & still have noticable gear whine but it's not real bad compared to the ones with straight gears.
The prochargers are louder. The quietest Prochargers are the self contained units. I don't know if they have a different cut of the gears or because of the internal oil sump dampening the sound or perhaps both.
[This message has been edited by IROCKZ4me (edited October 17, 2001).]
I ordered my D1sc with the noisey gears and it tested at 97dB's, Willie ordered his D1sc with the quiet gears and his tested at 96dB's...hhmmm not much quieter...
I can say that my blower is very noisey at idle and very low rpm's, but when cruising you hardly can hear it. until you tromp on the gas pedal, then hang on cause the road is going to get very short very quick!
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
Best E.T. 13.417 @ 106.89 mph. on worn out street tires
http://maniac.megamania.com
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
Larry,
What's the difference between the 9psi P-1SC and your 10psi D-1SC? The intercooler? I would get the "quiet" gear which would make it the P-1SC"H". Not much difference in sound you say, huh? Any problems with the install or other stuff?
Also, what did you pay and where did you get yours? I'm just about to order one through Tom Byrne's GP and the price looks real good. Just want to make sure...
Thanks!
Thanks!
'92 RS-SS,
The difference is the amount that each unit will flow, the P1sch flows 1200 cfm max, and the D1sc flows 1400 cfm max. also in kit form the 3-core intercooler come standard with the D1sc.
The biggest problem with the install is the instruction manual. too put it bluntly it SUCKS!
I paid just under $3800 with the polished blower from http://www.performancess.com
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
Best E.T. 13.417 @ 106.89 mph on worn out street tires
[This message has been edited by maniacc (edited October 20, 2001).]
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
Car: 92 Formula
Transmission: A4
Would anyone else suggest that he run the engine for a few thousand miles before putting on a power adder? I have heard that it is a good idea to let things wear a little.....
http://kiztope.50megs.com
92 Pontiac Firebird Formula 5.7/A4
K&N, nothing else yet!
92 Rs 3.1/T-5
Beautiful car, several mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
92 Rs 3.1/T-5
AIM : Theonekiztope
ICQ: 8787542
I can't really think of any legit reason (except maybe an empty wallet after a crate engine puchase
) for waiting to install a supercharger unless you are not experienced at tuning. If that is the case it would be a good idea to bone up on it before you even begin to do a swap to any engine or make any major mods with tuning needs unknown to you.
The supercharger should not be a tuning issue at all when not under heavy acceleration.
Then when under boost conditions you just need to be sure that the timing advance is not excesive and that the air fuel mixture is not too lean.
As far as "breaking in" the engine goes it will be just fine being broken in with a supercharger, turbo or nitrous system bolted in place.
As long as the engine is built soundly it will be fine. If it's not built correctly it will come apart anyway, power adder or not. The bearings & rings will wear in the same regardless.
If breaking in without the power adder was a neccesity then we would have had to take our twin turbo Supra back to the dealer after __thousand miles break in time without the turbos to then get the two turbos installed to keep our engine/powertrain warranty intact.
) for waiting to install a supercharger unless you are not experienced at tuning. If that is the case it would be a good idea to bone up on it before you even begin to do a swap to any engine or make any major mods with tuning needs unknown to you. The supercharger should not be a tuning issue at all when not under heavy acceleration.
That's awesome..but why do people prefer super quiet superchargers? Maybe it's just me, but I like that low whine...and I love it when cars drive past me and you can hear it...for you know, there lies POWER. :P
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K&N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Performance mods
Audio
Other
Irocz4me,
You are correct, When i get finished rebuilding a Caterpillar Diesel, as soon as the engine gets to operating temperature, the truck is put on a chassis dyno, loaded down, then checked for specified hp and torque.(600hp-1750ft.lbs torque @ approx 27 psi manifold pressure(boost)).
let me tell ya, if somethings not put together correctly, you'll find out right away.
And for BahamutRS,
I love my noisey ATI D1sc, i wish it was louder at times, so i don't have to hear those damn pony cars!!!
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
And for BahamutRS,
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
Don't get me wrong, the loud whine at full boost is awesome, but at idle, I don't want my car to sound like a street sweeper!!
I guess if your in the 500hp range, what's a little noise anyway? I remember how many heads my buddy's '89 GT would turn. It had a super loud Vortec S trim on a built 306, and man that thing was loud at idle and almost deafening at full throttle! Very nice...
Anyone have pictures of an ATI on a Camaro? Please post 'em!
here ya go,
for more pics of my set-up, goto my website(in my sig)
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
