I need some input.....
Old May 29, 2006 | 10:05 AM
jeffsbluez's Avatar
Car: 91 z28
I have just received my new D1SC with 3 core intercooler. I can not run it on my current motor because of the compression and the pistons. I have started a new motor project, but not sure about a couple of things. I have a new 4340 crank. and 4340 H-beam rods from Eagle. It is going to be 355. I am going to run gen 7 DFI with wide ban O2, AFR heads but not sure which ones, Je pistons, and I am going to have Comp Cams make a custom cam for my application. My questions for you are.....
1. Which set of AFr's should I run
A. 195's
b 205's
c. 210's
2. Injectors, how big and from how?
3. I have stock fuel rail, with a super ram. Do i need different fuel rails? If so will they fit with the super ram?
Thanks for your help
Old Jun 1, 2006 | 05:33 AM
jeffsbluez's Avatar
Car: 91 z28
PLEASE... I WOULD LIKE SOME INPUT ON MY COMBO. THANKS
Old Jun 1, 2006 | 01:31 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
go with the 195's . If you had more cubes ...maybe a bigger head.
Sentrek
Sep 2, 2010 08:51 AM
PONTIAC86style
Aug 7, 2003 08:44 PM
PONTIAC86style
Aug 3, 2003 08:48 AM
67 Camaro 88
Oct 11, 2001 09:22 PM
