What nitrous kit would you guys suggest to use with my Paxton?
Old Oct 21, 2001 | 10:55 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I'm running a Paxton and was wondering which nirous kit to get.? Not sure if I should use a plate like NOS or somehting like the NX system(whick I assume I would inject in the hole at the aluminum elbow).
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
160 degree thermostat
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
Paxton SN92
Old Oct 23, 2001 | 09:35 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
How fast is your car?
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Oct 24, 2001 | 11:42 AM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I haven't gone to the track yet with the Paxton but I ran a 13.6 at 103mph on my G-tech.I only got a chance to run it once though probably can get better times.
Old Oct 24, 2001 | 10:53 PM
SoCo80p's Avatar
personally i wouldnt risk running NOS unless you have a really tight bottom half (H-beam rods, forged pistons steel crank) anytime your using foced induction your putting a big stain on the bottom half of the engine along with the blower and nos will probley blow the engine up and you would need about 7-8:1.1 compression for it to be safe and work propery and if that 5.7 is stock it will be a 9.5:1 compression and wouldnt be a good idea. i would put the money into other parts on the engine, with a paxton alone you should be able to get it in the 11's with some better working on the engine. but agian, if that bottom half is stock and/or has high milage i wouldnt mess with it.
Old Oct 26, 2001 | 03:49 AM
Brad_Altec's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TempesT68:
personally i wouldnt risk running NOS unless you have a really tight bottom half.</font>
I agree, unless you are going for a 20 shot "intercooler".
Old Oct 28, 2001 | 02:42 PM
Car: 1991 Firebird
Engine: 427 LSX
I would advise to getting some respectable times out of your blown 5.7. Then buy juice, blow up your engine and then rebuild it strong.
1991 Firebird
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
toronto formula
Nov 10, 2015 06:17 AM
Street Lethal
Aug 14, 2015 08:25 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
