Old Nos TPI plate, interference problems with thottle body.
Old Oct 28, 2001 | 01:08 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I have the old style TPI plate with actual fogger nozzles. The problem in on the driver's side, the piece the throttle cable attatches to will physically hit the nozzle at about 3/4 throttle. I've already done some grinding/cutting, but it looks like I'm going to have to remove close to 1/2" from the back of curved throttle cable guide thingy. Did I do something wrong? or is this a common problem with the older style plate?
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Nov 11, 2001 | 10:17 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
No, you are right.
I had to do the same thing on my 89. The old style plate was designed for earlier throttle bodies. I grinded a good bit off the curved part until I could open the throttle blades all the way without it touching the Nos tubes.
Old Nov 11, 2001 | 11:05 PM
Engine: LS7
Yeah that's what I ended up doing. I tried a ~60hp shot 20 fuels and 28 N20s jets. I wasn't extremely impressed SOTP difference, but I G-teched a 5mph gain vs N/A g-tech time 99-100 mph(n/a) vs 104-106 mph w/NOS. Although my clutch started slipping in 2-3 shift, 3rd and 4th gear w/ the NOS.
This kit may be for sale if someone is interested. I'm thinking supercharger. It comes with everything needed(bolts/screws/etc.), (8) jets, fuel pressure guage mounted underhood,NOS pressure guage on bottle, micro switch, wiring to stock firebird foglight switch, and obviously solinoids, plate with foggers, and necessary braided hoses, bottle w/ brackets, stock Nos switches, blowdown tube(brand new not installed).
The plate has been opened up for 58mm throttle body and the person used a grinder(i.e. not perfect circles) and the blowdown tube needs another part to be installed (~$18-20), it's a different size emergency blow out seal to mate the AN fitting on the blowdown tube.
Old Nov 12, 2001 | 12:28 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i have that same setup on my car you can see
pics of it at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old Nov 13, 2001 | 10:43 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
darcom, you run crappy nitto drags with all those good parts?
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 15, 2001 | 01:10 AM
Engine: LS7
Explain yourself about Nitto and "crappy", They seem to provide a happy medium between tread life and traction for a daily driven car. I've heard generally 2-3 times the useable life than BFG drag radials, yet a little less grip and/or more heat needed. Most tires I have never last longer than 15,000 miles,hmmm. I've been debating over the drag radial thing for a while now. Goodyear GS-Cs are going on next($80 per tire/CarnDrvr deal). I'm just wondering since I already have a traction problem(maybe weak torque arm bushing/torque arm) since they are the only things stock still for my rear suspension. I don't understand how my car will light up the tires under acceleration in 1st with LCAs,LCA brakets, drag shocks. 3.42 gears.
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Sanjay
Aug 12, 2015 03:41 PM
