Tell me why I am wrong
Old Dec 4, 2001 | 02:02 PM
Yarnboy's Avatar
What if you had some sort of an automatic clutch on the input?drive?(one of those)shaft of the turbo that enguaged when the turbo spooled up to a specific rpm? It could drive a centrifical(sp?) blower. Does this seem like a fesible idea? It just seems like there is this shaft spinning at an ungoddly RPM that is not being used..Please refrain from replying with just "HAHAHAHAHAHAH"
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
I am looking for a 3.42 - 3.55 posi disc rear. cheesy@fred.net is my e-mail, send a letter if you can help!
Old Dec 4, 2001 | 02:32 PM
Blockhead's Avatar
AHAHAHAHAHAHAHAHHAHAHAHHAHAHAA
Yea .... but it's gonna to the big adios in a BLAZE a glory....
Director of Darwin Awards @ www.thirdgen.org
Old Dec 4, 2001 | 02:43 PM
Biochem's Avatar
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by Yarnboy:
</font>
Do you seem to get that response often? Maybe it should be telling you something about the types of questions you always ask! I, for one, have no friggin clue WTF you are asking...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Dec 4, 2001 | 02:51 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by Biochem:
</font>
yeah same here
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Dec 4, 2001 | 05:56 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
do you know how a turbo works? That shaft is used...to drive a centrifugual turbine or turbo. Thats the principle of the thing, am I missing something here?
Old Dec 4, 2001 | 07:19 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
let me get this straight..you want to have a "mad max" style clutch adapted to the shaft of a turbocharger and somehow engauge a centrifical style blower? correct?
if correct, in a word...no
79 Chevy Malibu Cpe
305 TPI/700-R4,3:50 Posi 9 inch,4 wheel disc
Custom Twin Turbocharged,Intercooled
ported upper and lower intake,
35 lb Turbo T-Bird injectors,
214,224 duration .450I .465E lift
749ECM, modified SyTy software
currently under radar
http://turbotpi.homestead.com/SATURN5.html
Old Dec 4, 2001 | 10:37 PM
ZBRA's Avatar
Car: 1972 Corvette
<font face="Verdana, Arial" size="2">Originally posted by SATURN5:
let me get this straight..you want to have a "mad max" style clutch adapted to the shaft of a turbocharger...........?
</font>
HAHAHAHAHAHAH I remember that now.
'94 Corvette Admiral Blue
-==ICON Motorsports==-
'91 Z28 Blue/Silver ZZ4/ZF6
335.9 rwhp 374.9 rwtorque
Old Dec 4, 2001 | 11:02 PM
Yarnboy's Avatar
Someone once looked at the spinning crank pulley on a motor and said "well that sure is a waste" I was just thinking along the same lines..I asked why it wouldn't work.. I am nothing short ecstatic that Biochem and Blockhead have suceeded in channeling their homoerotic frustrations through an electronic medium. And for their valor, I do salute them. That aside, a crank is doing something..so is the pulley..and a forced induction system was modeled in a way that it could take advantage of this. It just seemed to me that it may not be outlandish to wonder if something similar could be fashioned to take advantage of the shaft spinning at 100k RPM. Try and be constructive with your replies..If you need to write a reply just to prove you can use the literal skills learned in pre-school in a technical environment, please do so elsewhere. Thank you
  • Gutted Airboxes
  • Hypertech Airfoil
Old Dec 5, 2001 | 11:28 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
First a turbo isnt designed to have a load put upon it. Second it is precisely balanced. Hooking up some sort of clutch to one will not only kill its rpms (eg boost) when engaged but how to apply a clutch at +50K rotation. I suggest you learn about the differnces between turbos and blowers and how they operate..cheers Bob
79 Chevy Malibu Cpe
[This message has been edited by SATURN5 (edited December 05, 2001).]
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
