nodular crank
Old Nov 17, 2001 | 01:57 PM
agawam's Avatar
nodular crank
I'm putting together a std bore 350 it's an 86 4bolt block with a one piece seal this has a nodular crank I have trw forged flattops and 64 cc casting040 heads will the crank take a 150/200 hp shot of nitrous
Old Nov 17, 2001 | 04:06 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I would say it would take a 150 shot. Willie is running 12 on the dot in his 305 and he is using the stock rods and crank.
Rob
Old Nov 28, 2001 | 06:58 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
I have so far, but I also have splayed billit caps.
'91 Formula
383CI Superram, Sportman II's
SLP Cam 214/224 .470/.490
Vortech V1 S-Trim with custom 8 rib pullies
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
Old Nov 28, 2001 | 11:27 PM
PROCHARGED89Z's Avatar
Im pretty sure the factory crank is cast.An aftermarket company such as Scat,makes a good nodular 3.75 crank one piece seal.My friend building a 383 was considering this crank,the builder told him it would hold up to 700hp,as he had built alot of motors with this setup from Scat,with either nitrous or blower.Plus the crank is pretty cheap,alittle bit more than refurbishing the stock one.
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Nov 30, 2001 | 01:38 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I have a stock L05 short block in my car (only changed bearings) and by the looks of my MPH most would agree Im making near 475 or so HP at the crank on the bottle and its held up so far........knock on wood.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000rpm stall converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
13.0 @ 107- N/A
12.5@ 117- 100HP Nitrous
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Dec 6, 2001 | 12:08 PM
Metalifann's Avatar
All of the speed shops i talked to said that a nodular crank can hold up to around 700HP. I would think that a 150 shot of NO2 would be fine assuming the rods and fasteners can hold up.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
