People with NOS kit #5151 inside plz
Old Dec 5, 2001 | 03:55 PM
cobrakiller1989's Avatar
Can someone put up a pic of how the throttle switch is mounted on you car? I cant see how in the world this gets bolted up. thanks alot
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis strut tower brace
"There is no way you have a 350 in that car. They are made to have 305's and a 350 wouldnt fit"
-local parts store genius-
Old Dec 6, 2001 | 02:21 AM
Omar's Avatar
Cobra..I will post up a pic tomorrow, after i take a pic with my digital camera. You basically have to bend the cr*p out of the bracket to make it fit.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Dec 6, 2001 | 10:23 AM
Where did you bolt it to? The instructions sorta suck if you ask me. thanks
*1989 RS
*355 CID
Old Dec 6, 2001 | 11:41 AM
LIL QIK's Avatar
If I remember right, I bolted mine to the front of the throttle body. And he's right, you have to bend the crap out of it for position.
Old Dec 6, 2001 | 12:05 PM
89ROC's Avatar
I have that kit on my 97 Trans Am. I used the upper right TB bolt (if you're looking straight towards the motor from under the hood) I had to bend the bracket in 2 places, then had to cut the metal strip that presses the button on the switch.
97' black Pontiac Trans Am
350 LT1, A4.
CAI, Flowmaster cat-back, free mods, HPP3+, 3.42's, LT4 KM.
Vigilante 2800 stall. TransGo shiftkit. SLP headers (94-95 style). 100hp Nitrous.
Old Dec 6, 2001 | 04:57 PM
Thanks for the help so far guys. Installing my headers was easier than mounting this nitrous switch
*1989 RS
*355 CID
Old Dec 6, 2001 | 07:21 PM
jethro's Avatar
Hey, I went and put mine INSIDE the car... it looks much neater, I don't want all those damn wires running around... plus the piece looked cheesy, stamped metal. So... I mounted it to the bracket that holds the gas pedal and spring assembly/and cable under the dash. Don't have pics of it, but it works great, and I used the bracket they supplied.
Jethro
1987 IROC Z 13.92 and 1.92 60' street tires stock engine
Old Dec 6, 2001 | 10:33 PM
wiesman's Avatar
I did the same thing Jethro did. I really wanted to hide or disguise as much as possible. That switch had to go.
Old Dec 7, 2001 | 11:21 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
jethro, tell me that is a na time.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Dec 27, 2001 | 01:13 AM
Omar's Avatar
Sorry this is a little late...you have probably already figured something out by now.
db057
Sep 4, 2015 07:57 AM
fasteddi
Sep 2, 2015 10:29 AM
g.l.mos
Aug 22, 2015 12:02 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
92camaroJoe
Aug 13, 2015 06:07 AM
