It takes 20-25 foot-pounds....
Old Dec 12, 2001 | 04:26 PM
a73camaro's Avatar
Where is the tech section?!?!? Oh well
to rotate my half-way assembled engine. 350, +0.040, 3.75 stroke. Pistons with rings are in along with the cam and timing chain. No lifter and the heads are bolted on.
Anyone have similar numbers?
Old Dec 12, 2001 | 04:31 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
That # will go up as more of the pistons are installed. On a new engine it takes a LOT of work to get it to turn. Come pistons 7 and 8 its a workout.
Old Dec 12, 2001 | 04:32 PM
a73camaro's Avatar
All 8 are installed. That is why the heads are bolted (and sealed) on.
Old Dec 12, 2001 | 07:41 PM
maniacc's Avatar
if you don't have the lifters installed, it's gonna be harder to turn over because your not opening any valves.
later
larry
Old Dec 13, 2001 | 10:05 AM
a73camaro's Avatar
<font face="Verdana, Arial" size="2">Originally posted by maniacc:
later
larry
</font>
Wanna wager that?
Old Dec 13, 2001 | 10:44 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I guarantee that it will be harder to turn with the valvetrain in. I have heard that a 350 chevy need 45 foot lbs to turn.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Dec 13, 2001 | 11:08 AM
a73camaro's Avatar
I know what Larry ment. He just worded it incorrectly.
He said that it would be harder to turn an engine over because the engine is not opening any valves. So it would be easier to turn an engine over because the engine is opening valves.
Old Dec 13, 2001 | 11:09 AM
a73camaro's Avatar
So no one has don't this test to their engine?
Old Dec 13, 2001 | 02:15 PM
maniacc's Avatar
sorry, i had my head up my *** when i responded to this thread yesterday, what i mean't to say was it would harder to turn the engine over with the cyl. heads AND sparkplugs installed and no lifters, versus a engine with the cyl.heads, sparkplugs and valve train.
I'm sure there is a spec for the amount of torque it takes to roll the crank around, but i don't know what it is, but 20-25 ft.lbs doesn't seem bad at all, and as long as it rolls over smoothly you should have no problems.
so sorry.
later
larry
Old Dec 24, 2001 | 10:30 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
MANIACC got it right the heads and the plugs are the key to a hard to turn engine
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Metalizer
Sep 13, 2015 12:56 PM
Fox118
Sep 12, 2015 09:29 PM
formula1LE
Sep 12, 2015 08:31 PM
