Just got D1SC what should i expect during install ?
Old Nov 27, 2001 | 11:28 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Just got mine, and just wondering how hard and what to expect during the install ? Any tips and or helpful hints you might have would be much appreciated, thanks a bunch ! I look forwaed to joining the Supercharger club !!!!!
Old Nov 28, 2001 | 05:20 PM
maniacc's Avatar
Get out your swear jar, get a pocket full of quarters, perform your install, my bet is... you'll probably have enough change to pay for your new supercharger!!!
other than that it's not that bad...the instructions SUCK!!!
later
larry.
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
Best E.T. 13.417 @ 106.89 mph on worn out street tires
http://maniac.megamania.com
Old Dec 2, 2001 | 03:45 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I'm currently working with procharger to help them fix the 3rd gen instructions. the part about the windshield washer bottle relocate is the joke. even though it says to, dont cut the fuel lines as the FMU's now have been upgraded with hoses that have fittings to plug and play. also dont cut under the front end until you have test fit the 3 core inter cooler and seen exactly where to cut. I also had to "re-clock" the blower outlet on the head unit because it was 180 off. do not take it fully apart, just losen the screws and remove only the ones that get in the way (of the gearbox and the fill/drain plugs)and place them on the other side as you slowly slide it around. make sure you do not block the drain hole with one of them. I had to trim some of the upper radiator hose (radiator end) as well as about 7/8 of an inch of the radiator outlet itself, but still the blower belt was coming in contact with the hose about six inches down the hose away from the blower pulley so i cut this section out and replaced it with a section of chrome plated brass pipe that is made as a straight extention to an under sink trap (bathroom sink s shaped thing)about six inches long. I think it was 1 1/8" o.d. and used hose clamps it looks beautiful. after and during installation, never lean your weight onto the inlet piping on the passenger side because it is so close to the fill neck vent on the radiator (the part that goes to the auxilliary/vent coolant tank that it will break it off the fill neck. Also installation (including dyno testing/tuning) is available a short drive away for around $600 at Outlaw Performance in cheyenne wyoming (a Procharger dealer [where I work]) ph# 1-877-591-8558 -Tom
[This message has been edited by B4Ctom1 (edited December 02, 2001).]
Old Dec 2, 2001 | 06:20 PM
91Z28's Avatar
Car: 91' Z28
Hey Tom,
Thanks for the reply, i didnt get the intercooler with my setup because the previous owner kept it for his turbo setup, i still need the intercooler, what kind of deal could you get the cooler for, i would be willing to compensate you for your efforts. Thanks again for the valuable info tom !!!!
Jeremy
Old Dec 5, 2001 | 12:59 PM
91Z28's Avatar
Car: 91' Z28
TTT
1991 Z28 Modifications: 17x9.5 Tourque Thrust II's on dunlop sp 5000's, 3" cowl hood, repainted Red/Black racing striped all the way down to GFX, Pro-Kit lowering springs, KYB GR2's, Suspension engenering poly tie rod kit, Autometer dual guage pod with air/fuel and trans temp, Macewen white face layovers, Panasonic DF 88, Reactor 5" Tv, Plastation 2, K&N's, tpis throttle body airfoil, 3" pipes through high flow cats... no muffler, ATI procharger D1SC
Old Dec 13, 2001 | 08:26 PM
91Z28's Avatar
Car: 91' Z28
TTT
Old Dec 14, 2001 | 10:32 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
<font face="Verdana, Arial" size="2">Originally posted by 91Z28:
Hey Tom,
Jeremy
</font>
the best thing to do in this situation is to call procharger directly, make sure you have the serial nuber off your head unit or else they might not even help you. they dont care who owned the blower originally. they will get you the right parts or upgrades and an installation manual even, then once you have confirmed all that you need by giving them your name and all, i will call them and might be able to sell you the parts cheaper than they will but i will get them from them because thier pricing system directly from them is non competetive with thier dealers so we can install them here if you wish.
[This message has been edited by B4Ctom1 (edited December 14, 2001).]
Old Dec 19, 2001 | 02:29 AM
Bruce89TA's Avatar
Car: 89 Firebird T/A
maniacc is right.. The instructions suck but with a little common sense, you can get it together. Took me 5 months.. =o) Don't rush anything and make sure you know what you're doing before you get into it. The instructions do suck. Since you have a Camaro, you have a better chance at getting it right the first time.. The directions and pictures are of a camaro so you're ahead of the game already. Good luck. Oh yeah.. test fit everything before you start doing any mods and read the instructions. Some of it is actually pretty good. Good luck.
Old Dec 19, 2001 | 07:35 PM
Kandied91z's Avatar
what a pain.......600 bucks for install is a deal if it's guaranteed to work.
Old Dec 24, 2001 | 12:52 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
guaranteed and dynotuned we will even try to fix things like belt rub ahead of time so it wont be a problem for you later, also when I say guaranteed I mean for things within our control. i.e. not parts related failures like belts or pulleys or even larger parts but we will get you where you could not get on your own.
Old Dec 24, 2001 | 02:29 AM
91Z28's Avatar
Car: 91' Z28
i dont want to pay anybody to do, that would take all the fun out of building a hot rod, besides that 600 could go torwards some heads or somthing, time and patience is all you need to do somthing right
Old Dec 24, 2001 | 11:32 AM
vinroc's Avatar
too bad you guys are all the way out there not a bad price to save me $600 in asprin
Old Dec 24, 2001 | 02:06 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
keep us in mind anyway because for $120 (dyno $60, te we will dyno tune your car (it hasnt taken more than an hour)
Old Dec 31, 2001 | 06:46 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
B4C: damn I need you guys here in Maryland
NORTz89
May 20, 2020 03:51 PM
Vintageracer
Jan 10, 2020 05:33 PM
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
kyle5647
Aug 15, 2015 11:56 PM
