big nitrous
Old Jun 10, 2006 | 01:18 AM
krazy4's Avatar
big nitrous
How many of you guys on here are running huge shots of nitrous.
Like 200+ shot
Old Jun 13, 2006 | 09:55 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I used to have a twin plate setup running a 150 and a 70 shot, the 70 shot had a dedicated fuel cell I made out of the wiper fluid resevoir and it's own fuel pump. I didn't keep this on for long because the motor is a stock junkyard 87 TPI and I got paranoid that it was going to die a horrible death.
Old Jun 14, 2006 | 03:08 AM
EvilCartman's Avatar
Car: '82 Z28
I'm running a little 210 shot, it's fun.
Old Jun 15, 2006 | 12:08 AM
83 Crossfire TA's Avatar
I’ve run 250hp pills in my NX setup but with a JNMM to bring it in gently and I don’t believe I ever had it set for a full hit. Most of my “big” shots I was probably getting between 175 and 225hp from it.
Old Jun 23, 2006 | 05:04 PM
krazy4's Avatar
very cool guys
i wanted to see what a stock TBI with a 200 shot would run
anybody have any timeslips
Old Jun 23, 2006 | 07:46 PM
I'm trying to get a friend with a TBI Camaro to buy a nitrous kit, if it happens we'll see if he'll do the 200 shot. Personally I think you'de get pumping losses with the stock TBI heads and a shot over 150 but hey it'll be fun finding out.
Old Jun 24, 2006 | 12:50 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
hmmm, anyone seen or tried to run one of them crazy 600hp+ shots of nitrous?
Old Jun 25, 2006 | 12:50 AM
Car: '82 Z28
Friend of mine ran stacked plates, 350 and 250 shots. Melted the motor down before he noticed it was just staying on the rev limiter at 8600 rpm. Had some cool black marks for a 1/4 mile though lol. He's building a procharged all aluminum big block now.
Old Jun 25, 2006 | 01:05 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
i'll be putting the 200 jets in soon. i think i should do a little tuning beforehand though. i'm sure if everything works out i'll get bored of that and be looking into a pro race fogger or something else asinine. How much can a weeny 350 like mine take before it stops going faster and/or blows up? I'll find out...
Old Jun 25, 2006 | 12:36 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I had A NX Direct Port Fogger (Shark System) on my forged 383 W/ TPI. The unit was adjustable from 200 to 600 Hp. I ran the 200 Shot and then proceeded to crank the block in 4 places. After that I decided to build my current motor with a DART Little M.
Old Jun 25, 2006 | 03:20 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Chevy High Performance did a test on this a few years back. They took a stock 350 out of a junkyard (i think it came out of a C-10 truck?) and proceeded to hit it with spray on the dyno until it blew. I think they got up to a 225 shot before one of the pistons melted. Keep in mind, bone stock factory motor, sitting in a yard for a few years, i dont even think they put synthetic oil in it.
Pretty impressive if you ask me....
Old Jun 25, 2006 | 05:52 PM
vwdave's Avatar
Virgin Bore 350 out of a Impala I think. They rebuilt it with stock parts with a nitrous cam. They worked it a long ways, 225hp shot and when they were going to shoot a 250, they purged it at too low of a RPM and killed the engine. (Purged the nitrous into the engine.)
Thats what I remember at least.
Old Jun 27, 2006 | 10:28 AM
Car: 88 IROC
oh i didnt realize they had rebuilt it first. its been a while since i read that
Old Jun 27, 2006 | 01:25 PM
They didn't rebuild the bottom end, only replaced the valvetrain parts and head gaskets, and it was being fed a 325 shot and gaining power on there NA pulls, the 425hp shot being purged into it to low is what blew it up. Here's the article
Extreme Squeeze
I've seen similar craziness be done around here, the most extreme example was a 96 LT1 spraying an NOS 78 jet dry through the MAF meter, the car took over 80 pounds of nitrous and is still running to this day, the entire time it had a bottom end knock from the bearings being worn, that's why the kid was trying to grenade it with the nitro.
Old Jun 27, 2006 | 08:27 PM
vwdave's Avatar
Extreme Squeeze
After I posted that I thought about it and thought it might have been more. And I thought they re-ringed it.
Old Jun 28, 2006 | 01:51 AM
No re ring but they do mention the motor is in good shape, it's also a 2 bolt main motor. There are literally 1000 variables as to if your motor can or can't take a said ammount of nitrous, in this extreme test they're only using the nitrous for VERY short bursts, if you were to try and hold a 325hp shot on a stock 350 with only 1 heat range colder plugs for a 10 second quarter mile burst you would almost assuredly destroy it by the end of the run. NOS says that a TPI 350 can safely be sprayed with a 70 jet, my nitrous calculator puts this at a 180whp shot (no accessory loss taken into account). I plan on reinstalling the other nitrous plate and running a pair of .058 jets by the end of next summer now that the trans is rebuit. This will put it up to around a 250whp shot, and honestly I don't see the motor living a real long time on this but hey what fun is being conservative all the time.
Old Jul 1, 2006 | 02:04 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Extreme Squeeze
We're all guilty of having fun and breaking an otherwise healthy 350ci small-block. -From the Article Paragraph 1
lol
Extreme Squeeze
lmao
Old Jul 2, 2006 | 02:41 AM
FWIW, typically stockish engines in this range are somewhat self limiting… somewhere in the low 300hp range they just can’t take in much more spray and you start seeing a big cloud over the carb and power numbers don’t go up as fast as expected past there.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
