Inline pump still not working.....
Old Jun 17, 2006 | 05:35 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
So now im really confused, so im going to break it down, my inline pump wont come on with the car turned to the on position (not running) i replaced the relay, but that didnt help, the pump does work, i checked with the power wire and a good ground. The pump is wired correctly, but i still cant get it to come on, im thourghly confused, i tested for 12 volts at the relay, and it was fine, good ground, good fuse, but it just wont come on on the start position like it used to. The relay is T'd into the grey wire at the pump connector near the tank, i can hear my in tank pump come on but no inline any ideas whats going on here ?
Thanks !
Old Jun 17, 2006 | 07:31 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Either the pump is defective or worn out if it does have power and ground like you said it did.
Pull the connector off of the relay and install a jumper wire there or have some one in the car flipping the key on. Tap on the inline pump gently with a wood block. This will check if it is hung up mechanically or electrically.
If it is junk then you would probably be better off replacing the tank pump with something that fits your application and removing the inline pump. You have an extensive list of mods and the inline is just a failure point.
Old Jun 17, 2006 | 07:35 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
there is a wiring problem somewhere, the relay should have a ground to chassis, a 12V from battery, the 12v to the pump, and the switched 12v grey wire from stock pump
Old Jun 17, 2006 | 09:52 PM
vwdave's Avatar
I was about to ask if you checked the wire at the pump itself.
Old Jun 18, 2006 | 07:52 PM
91Z28's Avatar
Car: 91' Z28
yea the pump works, like i said i touched the power wire to it with a good gound and it turned over fine, ive triple checked the wiring connectors and there good, something dosnt make sense..... If i cant figure it out i may just wire the pump to a switch. The intank is a 255lph unit, but id rather not have it pump through the dead inline on it's way to the motor, i hear thats pretty hard on it....... And id rather not pull a perfectly good working inline pump, id rather have more gas than not enough on a boosted app.
Old Jun 19, 2006 | 02:45 AM
CrazyHawaiian's Avatar
Car: too many ...
Have you checked the power at the pump itself with everything connected and the power on? Verifying power to the relay proves the power is good up to the relay but will not prove anything about the pump. Divide and conquer baby! Check the power at the pump itself and if there is no power then you'll need to troubleshoot between the relay and the pump itself.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
