FMU Vs. Adj fuel pressure regulator
Old Jun 22, 2006 | 04:28 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Is there anyway that i can get rid of my fmu and just use an adjustable fuel pressure regulator in my Tuned Port car? I have to get a special one that can read boost right? Or can I use the one thats already on it? 24Lbs injectors seem a lil small for a 383ci 12lbs boost car? Thanks
Old Jun 23, 2006 | 12:38 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
With 24lb injectors on a 383ci need an FMU. The injectors are not large enough to spray the amount of fuel required at the stock fuel pressure.
A regular vacuum reference fuel regulator will give a small amount of fuel pressure adjustment and are not intended to supply extra fuel for boost. I use a stock LT1 fuel pressure regulator with larger injectors that can support the HP level of my engine. The LT1 regulator is a plain old vacuum referenced fuel pressure that will increase the fuel pressure 1:1. That is, it increase the fuel pressure by 1 PSI for every PSI of boost. It basically makes it so the injectors don't flow less when under boost.
Anyway, you need an FMU or larger injectors and a custom PROM.
Old Jun 24, 2006 | 05:15 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Old Jun 28, 2006 | 02:19 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
so if the LT1 regulator will work , why won't the stock TPI ( vacuum referenced as well ) ?
Old Jun 28, 2006 | 09:24 PM
midniteplowboyy's Avatar
Car: 91-Z28
Engine: SLOW ONE
It will if you have a big enough injector that doesn't need the higher pressure from the FMU to get the fuel flow.
Like me and junkcltr with our TT 350's were running 42's (well he is,mines still in pieces ) and I think were getting close to the limit of our injectors at near stock fuel pressures.
HTH
Old Jun 29, 2006 | 08:59 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I am thinking on trying the 42's with a 165 setup and just try the MAF tables to see if I can get an ...okay tune .
Old Jun 29, 2006 | 09:11 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
what kind of FMU would you need for a car puting out 12psi of boost, a 1:1 i know that the color of the FMU signifies what the ratio is like the blue one is different then the gold one well at least with the vorteck FMU.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
