tt 305
Old Jul 3, 2006 | 09:45 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
tt 305
i know it's been done a coupld of times but i'm looking for definite answers.
what 350 heads should i use and what cam should i use, where can i find a set of matching turbos, is it worth running maf tpi or should i switch to sd, can i take a set of sbc truck manifolds and flip them to mount the turbos?
and most importantly, do i need to run an intercooler or if i have ramair will the air be cool enough? and lastly how would i run oil lines?
i know these are a lot of questions but when i search everyone has different answers
thanks
Old Jul 3, 2006 | 10:29 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
the reason every one gives a different answer is because the possibilities are nearly infinite. I'll just tell you what I wish I did with my TT350.
High lift vortecs or 200cc e-tecs
something with more lift/duration on the exhaust similar to the cc306-8 would be nice 230/245 .510/.540
junkyards and ebay
almost all 3rd gens go SD
I don't really know, I though about it once than made custom headers
intercoolers are great to have. I can drive around for a while then feel the hot and cold sides of the intercoolers and feel at least a 20 degreeF difference
to the oilpan is the best bet, the the fp blockoff then the valve covers
Old Jul 4, 2006 | 12:01 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It depends on how deep you want to get into ECM tuning. If you do, then go with the SD because it is more adjustable and better documented. If you don't, search for user 89JYturbo. Copy his setup. It has proven to work well.
It is possible. Check out 89JYturbo's manifolds. They are they most straight forward way to build manifolds. He used stock TPI manifolds.
I do not have an intercooler in my turbo car (the IC is still sitting in the garage). The intake air temps are at about 100*F when driving around. They climb to 140*F sitting in traffic. I did one run with 7 PSI of boost after sitting and they climbed to 190*F (sky high). You don't need an IC but you would be better of with one. I built my setup without one so I could get it up and running and tuned. I have the IC waiting to go in........I need it.
Also, I have boxes that seal off engine heat from the air cleaners and get fresh air from in front of the tires (4"x4" hole at the bottom of the wheel wells).
thanks
Everyone does it different so you will get answers that vary. The best thing to do is read as much as you can and weed out the bad info. It all depends on what fits bests for you application.
Old Jul 12, 2006 | 04:04 AM
83 Crossfire TA's Avatar
200 cc runners are huge for a 305 unless he’s building a race car…
Again, way too big and totally inappropriate for a turbo
Old Jul 12, 2006 | 09:35 PM
Looking back at my post, you're right. Those would be better for larger displacement like a 383. I should have said that I would have gone a little bigger on the cam in my 350. I've seen boost at 1200rpm just playing around.
204 216 (@.050) .427" .454" 112LS
Old Jul 12, 2006 | 10:59 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
youre bleeding boost big time on a 112. whats your overlap?
Old Jul 12, 2006 | 11:23 PM
I got out my cam card and it doesn't have overlap, but I think it is 42*@.004" and 14*@.050. That is if overlap is the part when the intake opens while the exaust is still open. The cam card says for mild turbocharging, thats what gave me the idea back in 2003 to turbo my car.
I don't see a 112 anywhere on the card either, thats what was writen next to it in the magazine.
Old Jul 13, 2006 | 12:30 AM
-14* at .050…, but I still don’t like those numbers, maybe reverse the intake and exhaust so you have a 216/204. 111-114 LSA will work fine, I would choose the LSA based on the power band characteristics you want and compression/fuel/boot that you’re running
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
