pinging problem need help
Old Jul 16, 2006 | 12:19 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I have a 1988 camaro with a paxton supercharger i was having pinging problems so i replaced my 24 pounders for 30 pounders problem still there, i was running a stock chip so i had a custom tune done and added 42 pound injectors problem still there but only at around 3,000-4,000 rpm butif i stab itat full throttle the ping is not heard.the fuel pump is a walbro gss340m, trickflow heads.speedpro pistons.the egr work under boost.
Old Jul 16, 2006 | 11:27 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
When you go full throttle, the ECM enters power enrichment mode and goes rich so you don't have ping there. At part throttle and boost the ECM is trying to do 14.7:1 AFR which is too lean.
You have plenty of injector. It isn't a fuel delivery problem. It is the ECM trying to do normal part throttle 14.7:1 AFR. If you tried tuning the chip to add more fuel, it will try to take out fuel in normal part throttle closed loop.
Two choices. Use an ECM and/or MEMCAL that is designed for boost or run your current ECM in open loop and tune it.
You have the 165 ECM with $32B code. I had the same problem with the 730 ECM and the stock $8D AUJP code. They both try to maintain 14.7:1 AFR under part throttle closed loop and this causes problems when in boost.
Old Jul 16, 2006 | 12:25 PM
antoine's Avatar
couldthe tune be off.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
