Getting H20 injection to come on at certain boost w/ stock MAP
Old Aug 23, 2006 | 02:43 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Okay, I'm about 90% sure how to tackle a RMT. One of the few things left to figure out is getting an H20 injection system to work. What I am doing is the mechanical route, meaning stock memcal no prom burning. It can be done and I have been asking the Turbo Jedi about it.
But I can't figure out how to rig an H20 injection system to come on at a certain psi without the use of a 2-bar map and custom prom. Is there a way to do it mechanically easily?
Is there a way to time it? Or could I use a 2-bar map without prom burning?
What about in conjunction with an FMU? Is that possible?
Old Aug 23, 2006 | 03:11 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Some people refer to these mechanical switches as a Hobbs switches. It works just like an oil pressure switch. They close at 5PSI or higher depending on the model.
Old Aug 23, 2006 | 03:27 PM
Car: 1994 Trans Am
Close at 5spi? Shouldn't it open, again I have little clue about terminology. How hard is it to rig up? I was thinking 3-4psi when it would open......or close depending on what you meant.
Old Aug 23, 2006 | 04:37 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Something like this.
eBay Motors: Boost Pressure switch turbo water injection 1-25 psi (item 120021007388 end time Aug-25-06 16:17:34 PDT)
They sense boost and close an electrical switch when a certain boost level is acheived. The elec. switch supplies power or ground to the Water injection pump.
Old Aug 23, 2006 | 04:45 PM
Car: 1994 Trans Am
Does that hose connection go to a vacuum line?
Old Aug 23, 2006 | 05:01 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Yes, the hose barb connects to a vacuum line at the intake manifold. It senses boost and closes the electrical switch when boost exceeds the level you adjusted the switch to. The electrical switch turns on the H20 pump (switch closes).
Old Aug 24, 2006 | 02:15 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
You can probably use one of these:
NOS Fuel Pressure Safety Switches: NOS-15670NOS - summitracing.com
Old Aug 24, 2006 | 05:42 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
My snow performance Meth/water kit came with a pressure switch....BTW 3-4psi is probly too early...I tried starting that early and it ran like poop and it was hard to get the boost to build as fast..(I think the call it quenching the cylinders).....on at 6-8psi is perfect in my car....but they are all different and you will figure it out..I currently have mine switching on @ 8psi and it pulls like no other and allows me to push it to 15psi.
Old Aug 24, 2006 | 07:39 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
OlBlue: I have the same kit from Snow Perf. (stage 2 kit)... do you have a IAT gauge? if so, what are your temps before/after injecting? what are you injecting? just water?
Old Aug 24, 2006 | 08:50 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
No, I do not. I will say this tho...before after a hard run the plenum was hot to the touch when I laid my hand on it...now It not really even warm after injecting. I am running -20 washerfluid with great succes. hopefully I'll be getting dyno number in septemberwith and without the meth/water injection
Old Aug 24, 2006 | 09:50 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
When we were trying to fine-tune (right before my procharger exploded, lol) after a hard run my plenum would be at least ambient if not cooler. I was AMAZED at the impact the stuff has. and like Ol' Blue my kit (Devil's own) came with a pressure switch, I had mine coming on at 5-6 psi. Didn't get a chance to fine-tune it hough....
Ahh well, next year it will have a turbo and things will be different
Old Aug 24, 2006 | 10:11 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
We'll have her screamin next spring tho....I can't wait....
Old Aug 27, 2006 | 11:38 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Run a true alcohol setup.
Dont waste time with water and washer fluid.
One decent time in cool/cold weather and you will remember me saying this.
U were warned.
Razor/Julio has some nice stuff. Look it up under Alkycontrol.com
later
Jeremy
Old Aug 29, 2006 | 11:03 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Yes, the amount that is injected needs to vary with engine/ambient temps.
How much meth/water were you injecting to cause the problem and what was the ambient temp and IAT temp?
86White_T/A305
Mar 6, 2016 01:48 PM
customblackbird
Oct 1, 2015 04:30 PM
alpine247
Sep 16, 2015 05:25 PM
mackjar66
Sep 14, 2015 01:17 PM
Doobie52
Sep 11, 2015 06:19 PM
