Dual intank pumps inside
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Here are some pictures off what I have done......
The second pump will start at about 4psi of boost.
Some notes.
* The pumps must be mounted as I did and rotated as I did otherwise you wont get them in the tank.
* The Fuel level sender has to be apart when putting the pumps in.
* The electrical conector on one of the pumps must be disconnected when lowering the pumps down, as you rotate the unit.
* When the pumps are halfways down you can mount the fuel sender and the connector again.
Some notes.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
so how is it all wired up . One pump to stockwireing harness plug . Then the other ....
I have been trying to decide what I am going to do with my fuel system for my turbo project too.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Stock pump has stock wiring.
No2 pump has a fusible link direct from the battery to a relay, the relay is controlled by a adj. boost switch. I placed the relay on the bottom of the B-pillar.
Then a small diod that tells me when the switch is activated.
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Nice job! Which pumps did you go with, and how is the 2nd pump wiring sealed where it passes through the tank cap? It's tough to tell from the picture. Will you be changing to a larger fuel feed line (from the stock 3/8")? I'm planning on this same mod, since my fuel pressures are dropping off at anything greater than 10 psi boost (currently compensating with larger pulsewidths in the fuel map).
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Pumps are Walbro 340SS ( I think) its the high pressure ones....
Right now its sealed with a rubber seal and some sealent. Didnt have stuff home to solder/tig weld a pipe in the lid, but will probably do that this winter.
I'm not sure if I need a bigger fuel line, a friend has a -95 z28 running dual walbro intanks and stock lines, runs 9.44.......But the 4'gen maybe has bigger lines?
/N.
/N.
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Looks good. You could have also cut the ground wire at the pipe and soldered a piece to the top/cap. Then soldered another piece on the top of the cap and tied it to the ground wire at the chasis/plug ground.
Then use the dangling original wire for the second pump. No holes to drill and seal doing it that way. It does require soldering though.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Tried it today and it worked...... FP jumped up to 60psi so it went rich.
Question is when it would be best to start it? Its hard to tune if the FP goes up under boost..........
/N.
/N.
Engine: 5.7
Re: Dual intank pumps inside
I'm curious if anyone else has done this and can post results. Just curious did it up being a good solution or did you come back, changing it out, and end up doing something different?
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i just sumped my tank and used a mallory 110 FI pump with #8 up and back
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
tom86iroc; have you got any pics of the sump? I'm pretty sure I'm going to sump mine too...
Car: 1986 iroc
drk nope u really cant sump becasue of the hump in the trunk i actually just drilled a hole and had a weldin shop weld a fittin into the tank and i removed my plastic guts in side the tank i used a 1/2 or 3/4 to #8 fitting then i ran the line down to my pump ill try and get a pic but its tough with the heat sheilds up for the exhaust
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
The dual pumps works good, right now the tank is down again, I need bigger lines so its in progress. Will post pictures soon.
/N.
/N.
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Think you could post those pics back up, im going to be doing this shortly. thanks
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
