Dyno Numbers!
Old Sep 13, 2006 | 05:30 PM
TwnTrboZ28's Avatar
Dyno Numbers!
Just thought I'd share this with you guys.
So I finally took my hunk of junk to the dyno. Heres the combo first:
Stock 350 block from junkyard 60 over, I just honed it a little
Stock rods
Trw -15cc forged dish pistons
Arp studs/bolts throughout
2.02/1.60 stock iron heads, no porting
stock mystery cam from junkyard
Torker I single plane intake
holley 750cfm carb
Stock HEI dist locker at 24 degrees
Walbro 255lph fuel pump w 1/2 inch lines
MP T-70 turbo
BIG Ford Powerstroke intercooler
All runs done with 92 octane pump gas and timing locked at 24 degrees.
9 psi boost
Max HP: 389 hp 4700 rpm
Max TQ: 472 ft/lb 4300 rpm
14 psi boost
Max HP: 492 hp 4600 rpm
Max TQ: 563 ft/lb 4500 rpm
I have never been to dyno before, and I have to say it was pretty cool!
Old Sep 13, 2006 | 08:17 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Nice numbers. Is that at the crank or the rear wheels?
I like your setup. It is great to see good HP made on "non-high performance" parts. You mentioned 2.02" valves. Are they an old set of fuelies? I was eye-balling one of those Ford ICs. I ended up buying a Griffin 4" core for $150 new instead. Did you have to cut the Ford IC down?
What do you figure the compression is with .060" over, -15cc pistons, and 64cc?? chambered heads? I am surprised that it runs 14PSI on 92 octane. The IC must cool well.
Old Sep 14, 2006 | 02:31 AM
TwnTrboZ28's Avatar
Yes, I had to cut 3 rows off the intercooler. I think the compression is around 8.3:1. I only know that the heads are 2.02/1.60 and 76cc iron heads, nothing special. All the numbers are at the wheels!!
Old Sep 14, 2006 | 04:09 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Nice numbers, i wonder if my stock 305 shortblock could handle 13psi of boost
Old Sep 14, 2006 | 10:00 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Very good HP numbers for RWHP. I checked out the pics of your setup. It looks like you laid it out well with good pipe sizing.
I couldn't figure out what application the headers are for. Were they headers you had lying around or do know the model & year application for them?
Old Sep 14, 2006 | 11:12 AM
TwnTrboZ28's Avatar
They are the V8 S-10 conversion headers. I think I picked them up 3-4 years ago on ebay for $100.
Old Sep 14, 2006 | 08:01 PM
getit's Avatar
turbo power
Do you have alot of room for your exhaust? Will a stock hood fit? If not what would be in the way? Where did you get the turbo?
Old Sep 14, 2006 | 11:37 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
Very impressive numbers. Nice Job!
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
