Let me see you DIY single turbo hotside
Old Sep 25, 2006 | 11:32 AM
Tbird's Avatar
I am looking for pics of you diy single turbo hotside piping to get some ideas on mounting a large turbo on the passenger side...... looks cramped but possible... what headers are you guys using
Old Sep 25, 2006 | 11:55 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
C4 Corvette manifolds
Old Sep 25, 2006 | 12:03 PM
Tbird's Avatar
Would the drivers side have to be modified If I wasnt using powersteering? I am only going to be using an alternator. I thought about having both of the manifolds poiting down then on the passenger side have a 90 going up and connecting to te crossover? what do you think?
Old Sep 25, 2006 | 12:50 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
That should work since the power steering pump won't be in the way of the crossover pipe. You probably won't have to modify the drivers side manifold/header either.
Old Sep 25, 2006 | 12:52 PM
Tbird's Avatar
cool thanks for the help
Old Sep 25, 2006 | 05:13 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Vette manifolds here also...
Index of /images/CarStuff/92Z/TurboMotor
Old Dec 5, 2006 | 10:30 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
i know this is an old post but i had to ask...did you guys use "stock" c4 manifolds or did you use aftermarket c4 headers turned upside down?
Old Dec 6, 2006 | 02:18 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Those are stock C4 Corvette exhaust mainifolds.
Old Dec 6, 2006 | 05:56 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
What size turbine housings are you guys using? I have a 1.15 T4 housing and a T04B-Vtrim compressor laying around that i may consider using.
Old Dec 6, 2006 | 08:31 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
1.05 T6
Old Dec 7, 2006 | 12:09 AM
Car: 1989 GTA
what about using aftermarket c4 headers on a 400 sbc for a single turbo setup...would that work better than using the stock manifolds?
Old Dec 7, 2006 | 06:41 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
The purpose of using the C4 manifolds was ease of fabrication. The driver's side barely needed any modification. The passenger side required a bit more, but the manifold design made it easy to work with. Another benefit for me was that the manifold collects into a 2 1/2" tube, which was the same size as the crossover I ran. I don't know if you could get that from the headers.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
dusterbd
Sep 29, 2015 08:40 AM
