nitrous plate
Old Nov 7, 2006 | 07:57 PM
blockhead1986's Avatar
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
nitrous plate
i was curious i have a mechnical fuel pump would i have to switch to a electrical pump if i go with a nitrous plate setup for my carbed 355
Old Nov 7, 2006 | 08:47 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
How much of a shot do you plan on running? If your gonna keep the shot limited then you will be just fine with a high volume mechanical pump and regulator.
Old Nov 7, 2006 | 09:40 PM
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
probly no more then a 100 shot. who makes a good high flow pump right now just running a stock one.
Old Nov 7, 2006 | 11:54 PM
izcain's Avatar
Engine: 584
Any of the major manufacturers will work good. I personally run a 130 GPH holley mechanical with a holley adjustable regulator set at about 7.5 psi. I have ran a 175 shot with no problems at all and I plan on more. I normally only have it set on the 100 hp level though. I plan on putting on a big shot plate system and I think I will upgrade once I start really leaning on it (more then a 250 shot). You will be fine with a mech. one.
Old Nov 8, 2006 | 12:00 AM
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
sweet. right now iam also running a 600 holley would need to upgrade the carb to something bigger or just change out the jets
Old Nov 8, 2006 | 12:57 AM
izcain's Avatar
Engine: 584
The nitrous system comes with a nitrous and a fuel silonoid both of which will have to be jetted properly per spec on the system. U normally don't have to change the carburator jetting assuming you have a proper tune on it right now. You will have to tap into your fuel system for the fuel silonoid though.
Old Nov 8, 2006 | 10:31 AM
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
cool thanks for the help
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
