turbo tpi rockers and valve spring choices?
Old Jan 10, 2007 | 10:30 PM
bad383ta's Avatar
Cam specs:
dur @ .050 int 218 ex 225
lobe sep 114
lobe lift with 1.5 rockers int .519 ex .525
with 1.6 rockers int .554 ez .560
serial # Nu-Tek21912244
Just got the cam this week, what rockers and springs ect. would you recomend with this cam for a 350 tpi with a turbo?
the motor is apart right now, hopefuly we can get it back together in the next week or so. Heads will be going to the machine shop to be drilled and tapped for screw in rocker studs.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Sanjay
Aug 12, 2015 03:41 PM
