To turbo or not to turbo
Old Mar 7, 2007 | 11:54 PM
Demon2003's Avatar
I was thinking of going with a twin turbo setup this year on my 86 Iroc. It currently has a 383 stroker with a full forged rotating assembly. The compression is 10:1. I ve heard that oh just run a intercooler and meth injection and it will be fine then ive hear your gonna blow it up due to the high compression ratio. So i need to know what you guys think the engine is currently out of the car and i coud get some new pistons and get everything balanced but im already looking at prob 3k in turbo parts on top of that. Also how much did you pay for your turbo setup??
Old Mar 8, 2007 | 12:09 AM
TON*LOC's Avatar
Car: 1987 firebird trans am
Transmission: 5 speed
Axle/Gears: 4th 10 bolt hope fully it last
you be fine turboing that motor think of all the people turboing honda motors that have 10.2 -11 to 1 compresion with no problems. so have no fear in that. as for the money its really up to you are you tring to make it look all fancey or are you just tring to get the job done you can expect anywhere from $750-the sky is the limit.
Old Mar 8, 2007 | 12:54 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
do you have any idea how much a turbo setup will run you?? you cannot just go and buy a turbo kit for our cars.. you have to build it.. do you even know what turbo(s) you will use?? and at 10:1 compression, i would run 12psi intercooled max..
on another note, i would get that motor running top shape before deciding to turbo.. a 383 with the right parts, tune and suspension setup will run in the low-mid 11's on pumpgas.. how fast do you want to go??
you have 5 posts on this site.. go do a search on turbo stuff..
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
