tpi nitrous kit help
Old Mar 29, 2007 | 05:30 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
im ready to buy one i want the best complete kit i can get for my car looking to spray around 100-150hp i want a simple set-up what are my options?
Old Mar 29, 2007 | 05:35 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: tpi nitrous kit help
Before you do anything with nitrous, make sure you have a decent fuel pump. I have been looking into the kits at dynotunenitrous.com. they relatively cheap and the are decent kits. I have pretty much heard good things about them. The only downside to their kits is that they don't have the TB plate, but it does have a nozzle. I bought a plate at a swap meet so I am going to adapt it to the dynotune kit.
Old Mar 30, 2007 | 05:09 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
i was thinking of running the dry set-up but i also read that it should be sprayed before the mass air flow sensor what do you think?
Old Mar 30, 2007 | 06:14 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
I don't run nitrous. However alot of the guys I know prefer NX Express. If you are going to run a dry kit I wouldn't go with a very big shot. These kits depend on higher fuel pressure with your stock injectors to give the fuel, this is fine at low hp levels but doesn't leave much room to grow. When I finally get around to getting a kit it will be a wet kit. As far as where to spray if you don't use a tb plate then I believe that you should spray within six inches of the throttle body. Upgrade your fuel system. Upgrade your ignition or at least do a tune up. Depending on how big of a shot go with a cooler plug. You may also need to back the timing off. I believe a safe rule of thumb is two degrees for every fifty horse. And the most important thing for running nitrous is research. Good Luck!
Old Mar 30, 2007 | 06:15 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
dont get a NOS kit, get a kit from either dynotune or harris speed works, if u want feedback go to cz28.com amd there alot of thosae memebers runnign those kits
Old Mar 31, 2007 | 02:01 PM
niceroc said the same thing that i said. Dynotune is supposed to be good. As for the dry kit, don't do it! Be safe and go with a wet kit. With the wet kit you can spray more without having to worry about blowing your car to smitherines.
stalkier
Dec 6, 2015 11:25 PM
toronto formula
Nov 10, 2015 06:17 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
