NOS use
Old May 19, 2007 | 08:54 PM
86whitetpi's Avatar
Car: 1986 Trans Am WS6
Engine: 305 T.P.I
Transmission: 700 R4
NOS use
I just bought a 86 Trans Am with a 305 , TPI and 700R4. It only has 47,000 KM's on it. My question is will this motor take a 100 shot of NOS ? It is a street car but I want a little extra at the track. Thanks
Old May 19, 2007 | 09:02 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: NOS use
It will easily handle a 100hp NOS boost for years!
Old May 19, 2007 | 09:09 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: NOS use
Old May 19, 2007 | 09:11 PM
sp63
Guest
Posts: n/a
Re: NOS use
i have ran 3 ten lb bottles through my 163,000 mile 305 tbi in the past week. im about to up the 100 shot to a 150 shot.
i say go all out!
Old May 19, 2007 | 09:38 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: NOS use
dont mean to hijack but, I have a 350tpi that runs 14s flat and was wondering how much would i gain in the quarter on a hundred shot???
Old May 19, 2007 | 10:08 PM
86whitetpi's Avatar
Engine: 305 T.P.I
Re: NOS use
Well I guess a NOS kit will be finding its way in my car very soon. Thanks for the info.
Old May 19, 2007 | 10:45 PM
pairtoe's Avatar
Re: NOS use
there are better(and much cheaper) brands than NOS. look for cold fusion or dyno tune. but i guess its all a mater of opinion and personal experiences.
Old May 19, 2007 | 11:03 PM
sp63
Guest
Posts: n/a
Re: NOS use
www.harrisspeedworks.com
its what i went with, i have tbi so i went with the dual nozzle universal..
Old May 20, 2007 | 02:56 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: NOS use
Cold Fusion is good stuff, Dyno Tune isn't. I'de definetly go for the Cold Fusion kit even over NOS and I own mostly NOS equipment. Cold Fusion solenoids have big passages even in there small solenoids. There are also several brands that offer lifetime warranties on there solenoids which is great, it saves you the 30 dollar rebuild bill plus the labor when they inevitably start to leak or stick open. As for a 100 shot, it won't hurt a thing and will probably take seven tenths to a second off of your quarter time depending on traction. A 150 shot will help quite a bit more. My car runs a 13.5 on the stock long block 350 TPI, 12.2's on a 175 shot.
Old May 22, 2007 | 07:17 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: NOS use
Umm actually Dynotune is a great company, they use the same solenoids(manufacturer) in their kits as the cold fusion does so i dont know where you got your info from. And as far as solenoids go, they all need to be rebuilt some point or another, just like anything else, but ZEX solenoids are probably the worst ones out there. Compucar is another good company. Harris speedworks and nitrous outlet (nitro daves) are Really good stuff too. I would think that 100 shot on you're car would be just fine for a long time. Just dont forget the safety stuff and some of the other upgrades to help you maximize you're kit. Fuel pressure safety switch, window switch, bottle heater, and you should be good to go.
Old May 22, 2007 | 01:23 PM
Re: NOS use
Then stay away from Cold Fusion, the solenoids in the dyno tune kits are junk. I've seen 2 dyno tune kits both sets of solenoids started leaking within weeks from there install. These solenoids certainly don't appear to be the same, different orifices and even the bases appear to be made out of a different material. Where'de you hear that they're made by the same people?
Old May 23, 2007 | 02:42 AM
Car: 91 z28
Re: NOS use
hmm thats wierd, i've had a dynotune kit and i know a bunch of other people that have had them and had no problems out of them what so ever, and the soenoids have the same SN's..i dont know if they have switched manufacturers to cut cost but the ones that i got (about a year and a half ago) were the same as the cold fusion ones i have..beats me. I would just say got NX and be done with it, there stuff is no doubt the best on the market
Old May 23, 2007 | 03:06 AM
Re: NOS use
I was actually comparing the 2 fuel solenoids today and they're definetly different (cold fusion vs. Dyno Tune). I also would say go NX or Compucar and call it a day. You can't beat there warranty. I've heard from a few places that Dyno Tune has no customer service, I've not tried to send any of these solenoids back but I'm going to give it a try soon if they come through for me I'll be sure to post up about it. Until then I still say avoid them, it's a dangerous game when a solenoid breaks.
Old May 23, 2007 | 12:29 PM
Slick89RS's Avatar
Car: 89 Camaro RS
Engine: TURBO 94 LT1
Transmission: T-56 6 Speed
Axle/Gears: 10 bolt 4.10
Re: NOS use
I'm currenty running compucar, no complaints, no leaks.
150 shot on my lt1
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
