s.o.s
Old May 24, 2007 | 06:37 PM
19Irocz86's Avatar
Car: 1986 Iroc z z28
Engine: 305 tpi
s.o.s
this is a question im sure has been asked before. but icant find it when i search, but i am wanting to install twins or single turbo on my iroc. it has the stock 305 tpi in it. i just want 100-200 hp increase from street driving. i plan on building another motor to run of the turbo. but i need to know which is easeier and cheaper. single or twins. also i have no pipe bender but i do have a welder so fabing is not that easy. i dont care about keep ac or smog or anything i just dont want it to be a messy clutter under the hood. which is easier to tune twins or single? which are more effecient for street driving?? is is better to buy a kit or try to fab since I dont have a pipe bender. also what the best size turbo to run on the street?? thanks
if there is any member who sells pre-fab piping let me know
Old May 24, 2007 | 07:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: s.o.s
Why did you title this S.O.S? Why not something relevant, like single or dual turbos?
I think one member on here makes up kits for this. There's also one member on here that I know of who runs a single turbo on a 305 TPI. I think it made 500HP or so.
Single is a bit easier, but depending on how you size it, either one can make more power.
You can buy prebent tubing, mandrel bends, and/or weld-els and fab it up.
Old May 25, 2007 | 04:42 PM
19Irocz86's Avatar
Engine: 305 tpi
Re: s.o.s
sorry for the title
but i was wondering if it whould be best to by prefab piping then. all the other parts seperatly?
Old May 25, 2007 | 04:53 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Re: s.o.s
Single= less money, less piping, less cluter, same power. That answer your question? There are not too many "kits" available, so you may have some trouble there.
Old May 25, 2007 | 05:51 PM
19Irocz86's Avatar
Engine: 305 tpi
Re: s.o.s
gracies me amigo. what whould be the best headers to get?
james.gould150
Apr 11, 2011 08:25 PM
Funkycoldmedina
May 27, 2007 06:24 AM
dyeinbreed
Feb 27, 2003 12:47 PM
