nitrous plug #'s what do yall use?
Old Jul 10, 2007 | 01:03 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
well from what ive been told i should run the tr-6 in NGK or the autolite 103 gapped at .035 i am about to hook up my nitrous and im probably going to spray a 100 shot for the first little while im not going to go over 125. hopefully taking it to the track this weekend so i should have some numbers.
what plugs are you guys running i know the mustang guys seem to like the ngk brand a good bit over the autolites so i think thats what im gonna run is the tr-6's, my uncle is spraying his mustang with a 150 shot and it is running damn good so im anxious to get the ball rolling on this.
Old Jul 10, 2007 | 11:14 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: nitrous plug #'s what do yall use?
i know i answered this question at least 10 times by now...you are correct with you're research..TR-6's at .035 will get er' done..let us know how she does. Also if you go over 100 shot you might want to pull some timing.
Old Jul 16, 2007 | 05:49 PM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
ar133 autolite nice plug. This would be for a stock iron head motor works great on my 92 350 car still stock 6* timing base
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
89 formula TPI
Sep 7, 2015 11:06 AM
