ring gap
Old Jul 14, 2007 | 03:25 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ring gap
anyone have experience with ring gaps? I have file fit rings I am about to file and I cannot decide how much gap to go with. According to the chart I got with the rings, There is a N/A gap and of coarse a wider gap for blower applications, since I will be pushing about 15psi estimated with this engine I believe I want the wider gap but my only fear is oil consumption during normal driving. Anyone that has done this before have any advice? I don't want to be adding oil frequently because I have a ring gap that is too wide.
Old Jul 14, 2007 | 04:31 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
Re: ring gap
it wont burn oil, the top 2 rings are compression rings and the bottom one controls oil. u got to file them or the rings will butt together and tear the top off a piston.
Old Jul 14, 2007 | 06:15 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: ring gap
definitely use the wider gap without a doubt, check the oil and if it uses some, that comes with a blower motor
Old Jul 14, 2007 | 08:14 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: ring gap
Acording to Speed Pro:
Cast Iron or Ductile Iron Rings in nitrous (drag) applications
.007 per inch of bore
.028-.030 with a 4.000"
This is wider than the supercharged alone. Make sure you use them same torque plate and head gasket when you file the rings, as when it the block is bored and honed.
Federal Mogul's Tech line is 1-800-325-8886
Old Jul 14, 2007 | 08:38 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Re: ring gap
My rings are gapped for nitrous and it doesn't use any oil.
Old Jul 14, 2007 | 08:41 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: ring gap
really... i am running .028 end gap on my KB hypers. on a N/a engine
didnt see him mention that he had speed pro pistons... actually his sig says JE... so what ever # speed pro says is worthless along with thier tech line unless you like being placed on hold only to be told that you need to call the piston mfg.
Old Jul 14, 2007 | 09:15 PM
327???'s Avatar
Re: ring gap
I actually got the gap numbers from summit.
Old Jul 14, 2007 | 10:30 PM
Re: ring gap
Most radial ring thickness's are based upon SAE D-wall specifications. lateral gap between the piston and the ring is also based upon SAE specifications. Both Speed Pro and JE are based upon these.
Radial thickencess = (bore diameter)/22
But, yes i didn't notice he's running JE, probably would be wise to call them on an acceptable ring gap.
Old Jul 14, 2007 | 11:02 PM
Car: 91 RS
Engine: 350 vortec
Re: ring gap
okay so what does that have to do with his endgap on forged JE pistons and even the mfg. only gives a recommendation or a minimum because they have no idea what kind of insanity you are planning for an engine but at over $600 a set i would go bigger then they recommend probably not much though
Old Jul 15, 2007 | 12:07 PM
DIGGLER's Avatar
Re: ring gap
its better to be on the big side than on the small side.
Old Jul 15, 2007 | 03:53 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: ring gap
i know i would rather buy a quart of oil every month or so than be buying a new set of pistons!
Old Jul 19, 2007 | 10:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: ring gap
Thanks for the tips gentlemen. I went by what my paper recommended that came with the rings and after some of my own google research. I ended up going with a 24 on the top ring and 28 on the second ring and of coarse the 61 on the oil ring. this was for a 4.03 bore so its like .006 and a .007 and .015
This sound good to you guys?
edit: for the record my paper with the rings recommended .0055 and a .0065 for blown applications so I opened them up a lil bit more.
Old Jul 20, 2007 | 12:21 AM
xpndbl3's Avatar
Car: 1984 Z28
Re: ring gap
sounds like a plan, make sure to install them offset 180' for the top 2 rings
Old Jul 20, 2007 | 01:17 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: ring gap
yes of coarse, I would hate to mess that one up.
Old Jul 23, 2007 | 09:16 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: ring gap
I'm a bit late, but KB has a nice write up with explanation on their website. Basically they did a .080" ring gap (yes, HUGE!!!) and oil consumption was barely noticeable. As mentioned, the oil control rings take care of that. Bigger ring gaps save you from beheading the piston at the ring land.
I think I used .025" on my NA motor, just in case I ever decided to run nitrous. I can now run a 150HP shot or so and sleep well at night.
I'd run the bigger clearance on the top ring, since that's what sees the most heat. I think you're just on the edge, if it were me i'd go higher, ~.030" on the top ring. But that's just my wild assumptions there
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
