Intake manifold recommendations?
Old Jul 15, 2007 | 07:54 PM
xdamagedx's Avatar
Car: 1991 Camaro RS being built
Engine: N2o Injected 350
Transmission: Reverse Manual Valve Body 700r4
Axle/Gears: 3.73 Torsen
Does anyone have a recommendation for an intake manifold on my small block? I have a stock intake and a Holley 4160 with an adaptor plate. I was just going to slap my nitrous plate between my carb. adaptor and the carb, but there's no hood clearance and it's ugly. I bought an Edelbrock performer intake, hoping I could just bolt my Holley 4160 on there and use the nitrous plate without the adaptor plate being in there too. Nice plan and everything but it's 2" higher anyway, so it defeats the whole purpose. Does anyone make an intake that's stock height, but with a squarebore pattern?
Old Jul 17, 2007 | 11:38 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Intake manifold recommendations?
The edelbrock torker II has a square bore and it is pretty close to stock height. I'm using it on my current combo as well.
Old Jul 17, 2007 | 12:23 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
victor jr... not sure on exact height but its shorter than a rpm airgap.. or possibly an EPS intake(performance wise: a step above the performer, a step below the rpm)
Old Jul 17, 2007 | 12:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i fit a nitrous plate, and a vic jr under a stock hood, no air cleaner, but it fit. I have also fit a performer rpm air-gap under the hood with an L88 corvette drop base air cleaner, which is the lowest drop base they make IIRC.
Old Jul 17, 2007 | 11:20 PM
xdamagedx's Avatar
Torker II: Manifold height: A-3.53", B-4.63"
Performer EPS: Manifold ht: A-3.74", B-4.80"
Victor Jr. : "The low-profile of the #2975 works well in applications with minimal hood clearance and where 1" or 2" spacers can be used for performance tuning." ...nice and everything but no measurements I could find.
I tried the performer but it's too tall, so I'll assume the Torker is too. I'm picking up my drop-base air cleaner tomorrow, we'll see how much rrom that gives me. The Victor might be my narrowed-down option.... but Jegs price is: $197.99 ....ouch!
Old Jul 18, 2007 | 04:14 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
the torquer 2 is a good option, but you dont have many choices under the stock hood, especially with a nitrous plate. Ever think of getting a bigger hood, will make life easier.
Old Jul 18, 2007 | 04:33 AM
5678TA's Avatar
Car: 1984 Trans Am
forget the plate.. just get a fogger.. kidding
Old Jul 18, 2007 | 11:05 PM
xdamagedx's Avatar
I kinda want to keep it somewhat of sleeper. I DID consider it though, $420 at the local parts store, plus a paintjob
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
