How fast can I be bone stock with boost?
Old Jul 17, 2007 | 12:25 AM
89IROCZZ4's Avatar
I have been on the LS1 side of things for the past few years, and am interested in a third gen again. If I put a blower or turbo on a stock 350 (or heck, even 305) what kind of rwhp can I expect to see if everything else is stock? What other mods do you recommend?
Old Jul 17, 2007 | 01:15 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: How fast can I be bone stock with boost?
you need fuel lots of fuel
Old Jul 17, 2007 | 10:44 AM
89IROCZZ4's Avatar
sorry ... huh?
Old Jul 17, 2007 | 10:58 AM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
if you keep it stock you are going to run lean and destory the motor. at the least you need upgraded fuel pump injectors ect.
how much boost do you want to run. if i rember correctly it was said that for every psi of boost is a 7% increase in power and for every 10 dgrees droped in air temp is a 1% increase in power.
Old Jul 17, 2007 | 12:53 PM
hasty's Avatar
I'd say that if you got correct air/fuel ratios by some good injectors and tuning you could probably get away with 5-6 pounds of boost safely on premium pump gas if you had an intercooler. I would put a good set of headers and a free flowing exhaust on too because that adds power and makes an engine less prone to knock. With intercooled boost levels in that range you'd see about a 30% horsepower gain, so a 250 horsepower engine would jump to 325 horse. It would probably run about like a stock ls1 camaro, but if you did aluminum heads and a good blower cam I'd say you could make 500 horse on pump gas pretty easily if it was tuned right.
Old Jul 17, 2007 | 06:52 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
10Ibs is pretty safe on a stock engine if you can tune it right meaning new injectors and modified computer. Last few weeks I been running 15Ibs with a slipping 3.4" pulley no problems, should spike up to 17Ibs once I can get some more tension on the thing but I might just use this 3.7" pulley that I got in to be on the safer side.
Old Jul 19, 2007 | 09:45 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
my old 305 with 153000 miles made 390hp and 420ftlbs to the wheels at 13lbs with an ati procharger p600b. Had the supporting fuel mods though. It finally let loose two weeks ago. has a horrible rod knock now. Im sure it would have lasted longer if I would have babied it a little more, thats no fun though
Old Jul 20, 2007 | 05:48 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
a local guy is running 15 psi on a 305 TPI with meth injection and is running 11.8's in the 1/4 and puts down over 400whp.
jaridjohn
Jul 8, 2024 03:49 PM
Fast355
Dec 2, 2016 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
