Using Ford smog pump as a crankcase vacuum pump
Old Jul 19, 2007 | 10:07 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Has anyone heard of this? As I was reading this article, I wondered why I couldn't use a ford pump and simply filter the air entering it. They talk about a 30hp increase. If I got 20 I'd be happy for a relatively simple add-on.
Old Jul 19, 2007 | 11:02 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Using Ford smog pump as a crankcase vacuum pump
Yep, I actually have a Ford A.I.R. pump I intend on doing this very thing with.
Old Jul 20, 2007 | 12:17 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Doing more reading, I see there are some electric ones that would be the easiest. Some mustangs and also a lot GM trucks from 2001+.
All you need is a COALESCING filter ($40) to keep the engine oil out of the pump. Super simple hp!!!!!!!
Old Jul 20, 2007 | 02:33 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
my friend uses one from a s-10.. newer model of course.. i was plannin on doing the same..
if i remember, i'll take a pic of his motor tomorrow.. since its race day and all..
Old Jul 20, 2007 | 05:36 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Must see pics when this is done!
Old Jul 21, 2007 | 10:25 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I can find the coalescing filter (oil removal) but I'm having trouble finding a 1 psi hobbs switch. I guess you dont want the pump running when the motor's at idle.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
formula_novice
Aug 18, 2015 08:48 PM
86White_T/A305
Aug 17, 2015 12:16 AM
