Hey turbo guys wheres ur Battery?
Car: 1989 T-Top Iroc
Engine: 357
Transmission: Pretty sure it is a 700R4
Hey guys i am putting a single turbo on my 357 my intake piping is probably going to go through both my battery tray positions so mostly to the twin turbo guys that have no battery trays where are you relocating your battery?I just want to figure this out before i cut a hole in both battery trays and start piping for my Intercooler!
It is probably pretty simple but just checking!Oh and what Guage wire are you running where if it is not near your engine compartment?
Thank you much for any input!
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: Hey turbo guys wheres ur Battery?
I'm not a turbo guy, but most put their batteries it the spare tire well in the trunk. Can't recall the name of the company, but I know someone makes a bracket to put the battery there. Hopefully someone else will chime in...
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
just put it in the trunk, I have mine mounted in the lower well portion of the hatch towards the right side slightly. You do need a battery disconnect switch as well if you plan on racing it.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
mines going behind the driver's side hatch area panel (across from the spare tire well)panel, with the on/off switch getting mounted in the tail light and the recharge terminals going on a custom made panel behind the fuel fill door.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Mine's going in the trunk .... any pics from people who have done it before ?
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
stock battery location on my car and my younger brother's (see sig).
Engine: 357
Hey ttypecamaro u got some pictures of your routing? i would really like to keep it in its stock location.The track near us has a rule "if the battery is not mounted in stock location it has to be vented" i am not sure how i would vent it in the trunk!besides you guys may have thought of routing i would have never considered!
Please and thank you!
Also thanks for all the ideas keep them comming if anyone has anymore!
Mine is going in the trunk.
I am going to use a battery box and drill a hole through the floor of the box and the floor of the car and put a small tube in there and let it fly.
my pipes go through the lower air dam and over the radiator, had to cut out some of the support material on the hood.
best picture I have:
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That looks good, what power are you putting out with it? How hard was it to install?
thank you... a shade over 500hp@14psi... easy to install, but extremely difficult to fabricate... I need money to buy parts for my tranny and rear, so its for sale in the classifieds for cost of parts.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Here's how I routed my tubing to keep the battery up front. The intercooler is mounted right in front of the radiator.
Car: 1989 IROC-Z
Your batter yis on the side of the charcoal canister .. I take it you don't have one
Car: '85 TA
Engine: 350 turbo
Yeah, there's no charcoal canister or cruise control, along with other things I didn't feel like working around.
Engine: 357
Hey calebzman does you intercooler to intake pipe go into the fender?or just cut pretty tight to the battery?cause that looks like something that will work for me!
Thanks!
Thanks!
Car: '85 TA
Engine: 350 turbo
It does not go into the fender area. The tubing pretty much follows the sides of the engine compartment. I'll get some pics for ya.
Engine: 357
Wow!That looks pretty good!If i cut close enough to the fender i can still get the battery in from the looks of it!My intercooler intake and outlet are both on the bottom so i will have to go through the battery trays either way!Getting around the steering looks like a pain if i didn't do some cutting.Do you have any more good pics of all your routing at cardomain?If u do could u send or post me a link or even email me it?
At least i think u guys can check out my email address?!
both on the bottom? Flip it over and they're both on top, but I haven't seen your IC so maybe it doesn't quite work that way?
Engine: 357
Well i would flip it over but i will sill have to go through the body some where!The intercooler is in front of the radiator flush with the bottom radiator support.i will try to post some pics a little later but if i flipped it i do not think my bumper would go back on!lol!if it did i would not be able to have head lights and those are kind of a nacesity!lol!(I know i can't spell!)
Good thought though!
I will post some in a hour of two if i can figure it out!
Engine: 357
I know the car looks like a peice of crap but it cost me $400!I figure when i get everything the way i want it i will pretty it up!lol!It may make a perfect sleeper car if i don't.If it has the horse power looks aren't a biggie to me at least for now.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
