Holset Hx50W turbine outlet flange
Old Sep 14, 2007 | 09:36 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Does anyone know where to get one, or do I pretty much have to make one...
The measurements are 76 i.d. / 91 o.d. on the turbine... Mine is the flat faced housing, not like CEcoatings...
Old Sep 14, 2007 | 03:20 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Holset Hx50W turbine outlet flange
Try a diesel truck parts shop. The HX50 came on mid-sized diesel engines. Got a pic? Is it a 22* or 45* angle?
EDIT: Where did you get the v-band clamp for it? They should have the flange too.
Old Sep 15, 2007 | 06:54 AM
fun Pain's Avatar
Transmission: 4l80e
I don't have a v-band either....lol I will try a truck shop... I will get some pic's my dammmn Fuji cam died, but i have my good old nextel...lol
Old Sep 15, 2007 | 11:35 PM
junkcltr's Avatar
Engine: 3xx ci tubo
If the diesel shop can't help you then look at the Walker catalog. It lists all measurements and flange part numbers. If that doesn't work then call your closest Holset dealer. They set me up with a HX55W inlet gasket that no one else could get for me. I gave them the turbine part number and they shipped the proper gasket.
Old Jun 21, 2011 | 12:35 AM
83 Crossfire TA's Avatar
did you end up finding one?
Old Jun 25, 2011 | 12:40 PM
fun Pain's Avatar
Transmission: 4l80e
Yeah went to a semi exhaust shop that had all of it and even could flare 4in exhaust??
no green
Jan 9, 2016 09:22 PM
sreZ28
Oct 22, 2015 08:21 AM
customblackbird
Oct 1, 2015 04:30 PM
bplessy
Sep 30, 2015 12:14 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
