Nitrous kit - what ELSE do I need?
Old Sep 24, 2007 | 05:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm looking at the NOS Sniper spreadbore kit, $389 is hard to turn down. I am however cynical I can have my finger on the button for $400, I think it'll balloon by the time all is ready.
So my question is this, what ELSE do I need that's not in the kit?
- I'm not sure if a purge kit is really NEEDED. I'm not looking for max consistency at the track or anything. I could add it later if need be.
- This kit is apparently setup for 100, 125 and 150HP. What is needed to upgrade it to a 200HP shot say? New solenoid (s)? Just different jets? New line and all?
-What's the limit on a 4AN line anyway?
-I was thinking about putting a small (1 gallon) tank under hood, (drivers side, where the battery is not), and some kind of teeny electric fuel pump. Can I get away with the mr gasket $40 electric pump, or am I going to need a $100 pump? Any rules on what I need to run for a tank?
Old Sep 25, 2007 | 12:21 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: Nitrous kit - what ELSE do I need?
I will try and feild what I know.
-Skip the purge kit. This does not gain you anything.
-As for upgrading to a 200 shot I am not sure about that. Best advice to give you is call NOS and ask them.
-I think 4AN line is good up to 250hp. But this would be another good question for NOS
-As for a seperate fuel system. You could get away with a cheap pump. All it has to do is put out about 8 psi. Not to bad mouth cheap pumps but do you know what could happen if the pump fails?......Boom. As for a tank you will need to run a fuel cell.
-Oh and buy a bottle heater. This is a must in my opinion.
Old Sep 25, 2007 | 12:57 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A fuel pressure switch to close the solenoids if your fuel pressure drops below safe levels.
Old Sep 25, 2007 | 01:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Bottle heater? aww, that's getting really expensive isn't it? I figured that would only be useful if i'm using it up FAST, ie 20 seconds of shot at once, or two back to back runs, etc.
Yea, 8 psi and only about ___? (20?)__ gallons per hour. It just needs to be big enough for the nitrous shot HP level, my mechanical on block pump would take care of the engine's NA requirements.
Fuel cell - Can I fit that underhood?
Also, what's the difference between a fuel "cell" and a fuel "tank"? Both are containers in which to store fuel, so...?
Old Sep 25, 2007 | 01:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could put a 1 gallon fuel cell under the hood. It's the size of a 4L milk jug.
Old Sep 25, 2007 | 01:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Perfect. I wouldn't be using that much nitrous at a time anyway (any more than i'd need to drain a 1 gallon tank).
Apeiron, any idea on the going rate for 10 lbs of nitrous in the great white north? Or, better yet, a source for it?
Lets see,
$400 kit
$70 cell
$70 pump
$130 heater < maybe
$30 fuel pressure switch
$30 Misc fuel lines to plumb this all up
$600, + maybe $130. Well, $700 or so is about what I was realistically expecting. This would give me a reliable system though. Hmmm, later in the summer probably,....
Old Sep 25, 2007 | 02:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Davenport fills nitrous. IIRC it's something like $5/lb, but I don't know. I've still got a bottle of medical grade stuff that was filled sometime in the 70s. If you want to see how frightening nitrous systems were before the days of commercially available kits, I've got something to show you.
I think your budget for fuel lines is a bit low, I'd plan for $100 to cover everything you could possibly need.
Old Sep 25, 2007 | 02:33 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have about the same setup as you have mentioned. A sniper as a first stage and a NX kit for second stage. The fuel cell is mounted where the battery used to be with a Holley blue pump. I had to get a special cell that was about the size of a battery from a company on ebay. It wasn't listed but when I contacted them they made it for me for the same price. $75 if I recall correctly. The ones in summit were too tall and required cutting into the battery tray. Make sure to get a fuel pressure safety switch. They are adjustable. Mine is set at 5 psi. Just in case of fuel pump failure. An Advance auto parts 5-6 psi fuel pump can be used for about $30-$40.
Old Sep 25, 2007 | 03:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
I'll look into a cheapy parts store fuel pump. What would the application be for that? Just a "generic" carbureted electric fuel pump type of thing?
I saw dimensions for a few 1gal cells on summit, 6x6x12". I'll measure and check, but I wouldn't be against cutting out that plate if need be.
The only fuel lines I can think i'd need would be from the mini tank, to the pump, to the fuel pressure switch. After that I think the -4AN is supplied to go to solenoids and to the plate. I imagine a bit of hardline and some 45* flare fittings and 45* inverted flare -> NPT adapters would get the job done. $100?!? I wasn't planning on using those colourful anodized blue fittings and the woven metal braided lines or anything...
Ok, either way i'm looking at $700 when the smoke clears, to use a $400 nitrous kit. Sounds about right, after realism kicks in.
Old Sep 25, 2007 | 07:56 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Why use an under hood fuel cell? I don't think you're at the level that race gas is needed, not that it would hurt though.
Old Sep 25, 2007 | 10:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Nah, i'd most likely fill it with 92 or 94 octane, whatever is available.
I just don't think my mechanical pump on block would be able to pull enough fuel through the stock 3/8" line to power the engine AND a 200 shot of nitrous. Planning for a max of 200HP, start at 100HP obviously.
Other than an underhood fuel cell, what other choices do I have? T it right before the mech pump, and do the electric pump there for the nitrous, and the mech pump for the engine - but i'm not sure about that. I'm guessing 400 crank HP, plus 200HP nitrous eh?
Old Sep 27, 2007 | 03:38 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
If you want a very basic nitrous kit you can put one together part by part for under 400 dollars easily. I do it all the time for people, you don't need alot of the fancy add ons like purges and such, and if you're logical on your setup you can get great results out of mix and match nitrous parts.
Old Sep 27, 2007 | 10:37 AM
Sonix's Avatar
Car: 1982 Trans-Am
I figured it'd be cheaper to buy the kit. I know I can get the kit sans bottle for $100 less, but the bottle is most likely around $100 anyway right? Plate is...? Solenoids are...? Jets are...?
Hey, if you can let me know what kinda price i'd be looking at to piece together a "kit", such that I have jets for a 100HP shot and a 200HP shot, and everything else needed, let me know.
Old Oct 1, 2007 | 01:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Alright, i've come up with another question;
Is it legal (NHRA, IHRA, DOT whatever) to install the nitrous bottle behind the drivers seat? I'm thinking on the floor, basically at the back left passengers feet. This way I can reach around to open the bottle, rather than using a remote bottle opener, etc.
Old Oct 1, 2007 | 01:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It is if you vent it outside the car.
Old Oct 1, 2007 | 01:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Run the vent line forward then down through the shifter hole perhaps? Or is there a max length on the vent line?
Old Oct 4, 2007 | 02:25 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
great info!
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Pinguiclia
Oct 12, 2015 04:47 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
