Read this turbo map.
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Re: Read this turbo map.
That's not nearly enough info to determine if this is the right turbo for your application, you need to do a little more research to determine if this is right for you do a little reading on turbomustangs.com
that compressor is a little to small for your application, So unless youve got two of them, your motor will start to choke around 3500 rpms. Your going to want a turbo that is big enough to atleast support 6000 rpms. Plus its a diesel turbo and the impellers probably arent made of a material suitable for a gasoline engine.
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
