TPI fuel rails
Old Oct 30, 2007 | 07:15 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
TPI fuel rails
how much power will the TPIs fuel rail support? i plan on welding fittings and running -6 lines in and out. im just wondering if i should use a y-block, and then an aeromotive regulator. then id have to bypass those 3/8" hard lines that cross over.
i will be running a single T70 turbo, and im planning in the neighborhood of 450rwhp.
theres plently of forced induction TPI motors out there, so let see what you guys have done. -Jim
Old Oct 30, 2007 | 07:32 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: TPI fuel rails
enough to support your 450 w/o welding on AN fittings.
but you cant go wrong if your able to do it.
This Ta is runnung low 9's @150+mph with twin turbos.
http://www.theturboforums.com/smf/in...?topic=61219.0
Andrew6.688
Dec 13, 2015 10:59 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
