static turbo compression
Old Oct 25, 2007 | 03:27 PM
jed5161's Avatar
Car: 88 Trans Am GTA
Engine: 383 Lingenfelter/AFR 670 hp
Transmission: 700r4 3500 stall
Axle/Gears: 3.90 9 inch
what the most static compression you'd want and still be able to put boost to a motor and be worth doing it? i'm still gett'n my motor together and still have time to change a few things. I got flat top pistons and .042 head copper head gaskets putting me at 11.6-12.0:1. I know with the heads i got and the deepish dished pistons (shelf piston) available from JE the lowest i can get is 9.8:1
Old Oct 26, 2007 | 05:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: static turbo compression
9:1 is about the limit when you want any amount of usable boost
Your heads are wayyyyy too small for a boosted engine. Might as well put it together as a NA motor, maybe a bit of nitrous.
Old Oct 26, 2007 | 08:57 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
are you running a 48cc chamber? im confused how a flat top piston can get 11.6 my 357 turbo motor for a t88 has je pistons and has 8.4:1 comp
Old Oct 28, 2007 | 12:57 PM
lbman0007's Avatar
Car: 1986 Chev Camaro
Transmission: Th350
Axle/Gears: 10 bolt 3.23 posi
how much nitrous can you use if static compression ratio is 11:6.1?
Old Oct 28, 2007 | 05:14 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Go to a .057 head gasket and have the chambers opened up a bit. as for a limit it would depend on the tolerance of the motor. Aluminum heads help a liottle more with detonation.
Get it down to 9.5 to 1 or so and run good fuel(or an alcohol kit) and you'll be fine......
plenty of people running boost with high 9's static.
My last TTA had a little over 9 to 1 with iron heads.(GN pistons with the smaller TTA heads).
Old Oct 28, 2007 | 06:52 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
well a typical pro mod motor runs compression as high as 16:1 and they spray arround 1000 hp shot. so that is a loded question.
on my 355 i spray 225 and have sprayed 275 on 12.4:1 pistons. no delay
Old Oct 29, 2007 | 08:18 AM
jed5161's Avatar
measured them out just to double check myself and they came out 48.5-49 cc. me not thinkin... go figure...when mock'n up the motor the piston was down in the hole about .022. (changed blocks). i should of left it there. i had it milled to flat
Old Oct 29, 2007 | 09:14 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
what kind of heads are they . 18deg. thats a tiny chamber if they are 23 deg i would worry about valve shrouding problems. you still would need arround a -36cc dish to get to low 10s high 9s.
Old Oct 31, 2007 | 08:21 AM
jed5161's Avatar
they're Air Flow Research heads. they were milled at factory to bring compression up on the stock motor to mid 10's. came in a kit from that was setup by lingenfelter performance in mid/late 90's purchased through tpis. at least thats what i understand. the kit came on the car when i bought it. they're cnc ported intake and exhast. cnc chambers. im a dealer for profiler heads so im debating on gett'n me a set of those and sell'n these AFR's
Old Nov 2, 2007 | 05:00 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
the only problem with them now would be if they were angel milled that much you would not be able to run as much camshaft.
FormulasOnly
Jul 23, 2018 08:47 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
