Starting a 383 turbo project.
Old Nov 4, 2007 | 06:42 PM
GMODUDE's Avatar
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
Im looking into an L98 or an LT1 which i would bore .030" over. I am wondering about the Cam I should run. Would an LT1 cam or a ZZ4 cam be better? Or should i go higher?
Old Nov 4, 2007 | 06:55 PM
GMODUDE's Avatar
Car: 92 Camaro RS
Re: Starting a 383 turbo project.
Im trying to get 400-500 hp and that same amount in torque. The 16ibs turbo should help but what do you suggest on the engine build up.
Old Nov 8, 2007 | 12:46 PM
Raider9170's Avatar
Car: 1985 Iroc/z28
Engine: '70 LT1
I would definately say if you are going to put in the effort to turbo the thing you should call and get a grind specifically for forced induction. They are pretty specific for turbos/nitrous/blowers and in the end it will be the best for you.
Old Nov 8, 2007 | 01:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moving from Engine Swap to Power Adder.
Old Nov 10, 2007 | 05:51 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
for turbo, i would suggest something around 114-116 LSA to keep the idle pretty smooth for better spool. Custom grind would be your best bet.
The lt1 cam is 202/207 dur .450/.450 with a 117 lsa
ZZ4 cam is 208/221 .474/.510 not sure on the LSA
Old Nov 12, 2007 | 02:30 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
If you are asking this question, I have to ask. Have you ever done anything like this before?
Old Nov 12, 2007 | 10:34 AM
Car: 91 z28
my guess is no.
Old Nov 12, 2007 | 04:30 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Well with only a measley 400-500. you could hit 400-500hp easly on N/A easly. I bought a super charger and wished I never did cuz for the 600hp goal I could go N/A and save a ton. My new motor is a ZZ383EFI cleaned ad ported. With a 125hp Nitrous= over 500rwhp of fun.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86White_T/A305
Aug 17, 2015 12:16 AM
BurlyChev
Aug 16, 2015 09:08 PM
