125 shot + stock 700r4= ???
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
i was wondering if a stock 700r4 will hold a 125 wet shot thru gears. my 700r4 still shifts strong and want to know if i can just arm my zex system and push the pedal to the metal traction wont be problem i can get some slicks.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 125 shot + stock 700r4= ???
I would do a WOT switch and a button, that way you can hit the dope and have it only activate at full throttle but release the button while it shifts to prolong life. I have hit it and stayed in on N2O, but the automatic gets wore out way quicker than not having it on while shifting.
Car: 1986 iroc
already have the wot switch but how can i wire the on/off button? can i just wire it to the ground on the management unit? thanks. hey do you go to houston motorsports park?
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I had my stock 700r4 and a 145hp shot of juice.
It lasted for about 2 years.
I had a shift kit and that helped.
If I did it over again, I would have used the rpm window switch I had and turned off the juice in between shifts.
I have rebuilt my tranny now and no problems so far!
ambainb
Apr 25, 2016 09:21 PM
