V8 Twin Turbo Kit Questions
I have a 1992 Trans Am and am looking for some ways to improve the performance greatly. I was looking at eBay and noticed some twin turbo kits. Are these easy to install and would they greatly improve performance? Are there any other recommendations to improving performance that I should consider before looking into these? Any help would be greatly appreciated. Below is the link to one of the auctions that has twin turbo kits available for V8s. Would there be any additional parts that I would need to be able to add a twin turbo to my engine that isn't included in this?
http://cgi.ebay.com/ebaymotors/ws/eB...m=280186104059
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: V8 Twin Turbo Kit Questions
Easy to install? No, anything that says "fitment and downpipe required" means you are going to have to fabricate. If you can weld, and do it all yourself its not a bad thing. But for the welder impaired you are going to have to find someone or a shop to do it for you.
That link reminds me of the S&S Autochrome rip-offs. I'd research alot before buying it, the S&S autochrom turbo headers are known to crack and cause problems.
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
here is one of the more recent threads on the ebay turbo kits:
https://www.thirdgen.org/forums/powe...-789-ebay.html
From experience, I think it ends up being easier to build your own kit. Either way you HAVE to weld and fabricate.
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
let me put it this way. my t88 turbo alone was 2800 bucks.
and nothing else. if a turbo kit costs less than 3500-15000 range depending on power level. ill have close to 10,000 in mine
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
That thing is a monster. You just missed a low miles Garrett GT47 series T88 with a 1.22A/R turbine on ebay for $650. The Borg Warner S400 series can be machined for an 88mm wheel for under $1500 if I remember correctly. That T88 should rip. What did you choose for a turbine?
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
the 80mm s400's (s480's) are only 945 new and can support like 1300hp.
Terrell351
Jun 13, 2021 01:13 PM
Mickeyruder
Sep 2, 2015 02:45 PM
