Will this damage fuel solenoid??
Old Jan 26, 2008 | 08:24 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
my fuel solenoid for my nitrous system is hooked up to the fuel pressure guage port on the fuel delivery block coming off the carb(holley dp). My question is because its hooked up that way, even when i'm not spraying the fuel solenoid is still seeing constant pressure because its hooked to the pressure guage port....is that good or bad for the solenoid??
P.S- everything is wired to an on/off arming switch if that makes a difference.
Old Jan 28, 2008 | 10:59 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Will this damage fuel solenoid??
Mine is hooked up off the fuel rail and sees constant pressure everytime the motor is running. I've been driving around for years with this set-up. Unless you run a seperate fuel system for the fuel side, it's ok.
Old Feb 6, 2008 | 05:05 PM
thanks man, just wanted to know that i'm not shortening the life of the solenoid by having it hooked up that way.
Old Feb 6, 2008 | 05:17 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
In every Nitrous setup there is always pressure on the solenoid. Even in a low pressure seperate fuel source setup. It is fine.
BlueIroc-Z
Jun 9, 2019 03:22 AM
jklein337
Sep 19, 2018 06:23 PM
fasteddi
Sep 2, 2015 10:29 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Zachattack0925
Aug 12, 2015 09:52 PM
