450 hp 383 tpi
Old Feb 5, 2008 | 07:59 PM
91rscamaro83's Avatar
Car: 88 iroc z
Engine: 350 tpi
Axle/Gears: stock
450 hp 383 tpi
I found an article on superchevy.com. They did a build up of an l98 from a corvette. They put a 383 kit in it, a new cam, ported the plenum, and base. They got aftermarket tpis throttle body and runners and ported the stock heads. They got it to pull to 6000 rpm's and it made 458 hp and 534 lbs-ft of torque. I thought that was pretty amazing. Oh and heres the link http://www.superchevy.com/technical/...ion/index.html
Old Feb 6, 2008 | 02:04 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: 450 hp 383 tpi
Yup, bigger ci, bigger intake, bigger heads will make more power. Now all it needs is a 200 shot of nitrous.
Old Feb 6, 2008 | 03:09 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: 450 hp 383 tpi
I read that one a while ago. Pretty darn good for some stock heads. I wonder how much more torque it would make with some RHS vortecs.
LT1Formula
Nov 16, 2015 01:13 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
