Third Gen 3.4L Supercharged questions
Old Mar 27, 2008 | 09:35 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
When rebuilding my firebird I went with a 3.4L motor from ARI racing, port polished heads etc. does anyone know of a supercharger kit for this, RSMracing makes a kit but its for the SFI3.4L Grand Am motors. I also know powerdyne makes one for the 3.8L Camaro
Not sure whats available just researching and shopping
Any ideas???
Old Mar 27, 2008 | 02:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Third Gen 3.4L Supercharged questions
I don't think the 3.4L was ever offered in a longitudinal mount eh? Think the blower for the transverse grand am would work? I think with a few tweaks it would.
Out of curiosity, what drove you to get a souped up 3.4L?
Old Mar 27, 2008 | 03:59 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
93-95 camaro / firebird
Old Mar 27, 2008 | 04:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Huh, I thought it was only the 3800 that was available as the barebones model for the 4th gen... But come to think of it, you're right, slipped my mind I guess.
I don't think there's much in the way of hot rodding the base model though, which begs the question of why?
Old Mar 28, 2008 | 04:56 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Last I had heard RSM (Z-Spec now, I think) made a supercharger kit for the 3.4L Camaro. They also have it for the FWD 3.4 (3400). Mounting, for the FWD one, is going to be different...but it is probubly doable.
I looked into the 3.4 Camaro package a while back, they said that they could still do it but it wasnt in their catalog. I think it was around $3400, which was WAY to much for me.
They also have one for the Fiero.
But regardless which way you go, its not going to be a "bolt-on and go" kit. They all have things that youll need to get done to them.
FWD--> Retrofited for the RWD and ECM tuning
3.4---> The 3.4 ECM tuning wont work for you.
Fiero-> Pipes, Mabye mounting, and mabye tuning
Old Mar 30, 2008 | 07:24 PM
kelham's Avatar
Sonix, I went with the 3.4l because I dont want to swap to a v8
I have v8 385 fastburn but this car I want to leave a v6
I dont want to swap harnesses etc, plus I can pull 200 + hp out of the 3.4 with select mods, + ari has a really good deal going for one right now
Old Mar 30, 2008 | 11:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
AH, gotcha. I figured if you have the big HP car, then why not leave the other one as a basic get around vehicle with max economy. But hey if you got the money to hotrod both, why not eh? (must be nice)...
Old Apr 1, 2008 | 04:46 PM
kelham's Avatar
Im just looking for an upgrade off the 2.8l, its leaking everywhere, burnin oil bad. and the trans in on its way out too, the body is mint and just got painted midnight blue w/ black flake, so its kinda a way to push myself into a new engine and trans because other wise I dont have a daily driver anymore
Old Mar 27, 2011 | 06:07 PM
billydunn5's Avatar
Car: 1994 Firebird
Engine: 3.4L v6
If you swap the heads with a grand prix 3.4 you can put the supercharger on with it. the 3.4L sfi is the most restricted engine the gm has ever made and if you can pull all those restrictions out it will keep up with a lt1 350, i got a buddy that did it and its quick as hell now.
Old Mar 27, 2011 | 06:21 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
itd be a little more complicated than just swapping the heads to make that work. the other problem with getting one made for a 3.4l camaro is its going to be based of the 4th gen which will lead to a few other custom tweaks to make it work.
id have to see the kits available to know for sure, i went the turbo route it was a lot easier in my eyes to do
Old Mar 27, 2011 | 07:57 PM
billydunn5's Avatar
Car: 1994 Firebird
Engine: 3.4L v6
I also Think that swaping a 4.3L v6 in a firebird would be a cool idea...
Old Mar 27, 2011 | 09:30 PM
project89's Avatar
same work as swaping in a v8 except for the fact the 4.3 will need custom mounts, theres a thread on it in the engine swap forum
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
