Need help installing manual blow off valve.
Old Apr 11, 2008 | 05:19 PM
Excellegions's Avatar
Car: 91 Camaro TBI 5.0
I got on ebay #370026622302, a turbo with a twin port internal wastegate and a two port manual boost controller. There is a tube already going from the turbo housing straight to one of the ports of the internal wastegate, the other port is open. The boost controller came with a T fitting and has two ports. can some draw up how Im suppose to put this together!?
Old Apr 13, 2008 | 10:16 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Need help installing manual blow off valve.
I think you mean manual boost controller instead of blow off valve... anyways... this is essentially what you need to do, just put your brand MBC where theres is. http://www.jimwolftechnology.com/wol...STRUCTIONS.PDF
Old Apr 14, 2008 | 05:14 AM
Yeah, I did mean manual boost controller, to funny, that diagram is cool, but my internal wastegate actuator has two ports, how does that work?
Old Apr 14, 2008 | 11:53 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Hello Lee,
Basically the port next to the threaded shaft on the wastegate when pressurized it increases boost and the other port lowers the boost.
1992rs/ss
Jan 31, 2025 05:10 PM
RazorN8
Jan 7, 2022 11:44 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
backtothe80s
Sep 5, 2015 12:39 AM
fasteddi
Sep 2, 2015 10:29 AM
