Turbo oiling and turbo questions
Old May 19, 2008 | 02:13 AM
bigjay89gta's Avatar
Car: 89 GTA
I was wondering what size T-fitting I need to tee off the oil pressure sending unit to supply oil to my turbos.
Also I was wondering what is the best way to get the oil back into the motor.
I am getting everything together to do a RMT setup. I am going to use a Mocal differentail oil pump and either a T70 or T3/T4 turbo. I plan on pushing about 7 psi now and later rebuild and go for 15 psi.
What size turbo do I need for this. I have been researching and it seems I need an A/R in the .50-.63 range. Is this correct?
Any help is greatly appreciated.
Jason
Old May 19, 2008 | 07:37 AM
Reputation7's Avatar
Re: Turbo oiling and turbo questions
a/r is far to small. your gonna need something in the .96 range. and also the t70 is a bit small. personally i would do it right the first time and just get a T76 with a .96 a/r. it will breathe right on the car until you turn it up and try and go past 800+hp.
Old May 19, 2008 | 04:23 PM
project89's Avatar
i believ all the rmt mount setups do use a .63, at most i would go with a .84 housing though im unsure of how laggy that would be on a rear mount system.a real t70 is all u need.a t4 57 trim coldside will be on the small side for a 350 so deff got for the larger one
Old May 19, 2008 | 04:54 PM
woooo didnt see the part about the rear mount. durrr.
Old May 19, 2008 | 06:53 PM
Car: 89 GTA
yeah I definitely want something with a quick spool. Also what about the Tee fittings.
Old May 19, 2008 | 09:06 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
1/4 in going into the block [pipe]... upper and lower oil ports in the block
I am returning mine into the Mech.fuel pump plate...
Street Lethal
Apr 30, 2019 12:14 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
