post your single turbo set up pics here
Old Jun 3, 2008 | 02:07 PM
bob8703's Avatar
hey guys. i am wanting to put a single turbo setup on my car and im having trouble with how im going to set it up. i wanted to relocate my battery to the back and put the turbo near there and the inlet to the intercooler through where the battery sat. then run it up through where the air box was and to the intake. i would also do it vise versa. but i dont know if that is the easiest. so i would like to see how other people did the setup. all i know so far is that im going to get a t3/t4 turbo to use. once i get that i will move on with buying the rest of the stuff. im not even sure if there will be enough room to place the turbo there.
Old Jun 3, 2008 | 06:26 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Re: post your single turbo set up pics here
I just got everything where I wanted in these pic, but you get the Idea, I have been using all stainless parts and steel. And this photo doesn't have and cleaning done yet or turbo covers. Sorry but Enjoy
Old Jun 3, 2008 | 07:03 PM
bob8703's Avatar
nice. how hard was it to install. and are you able to close the hood without having to mod it or replace it with and aftermarket.
Old Jun 4, 2008 | 07:57 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
T72 with BBS header. Eventually going to run a pipe for the filter down where the battery was. Its in where the spare tire was now.
Old Jun 4, 2008 | 04:30 PM
bob8703's Avatar
Originally Posted by lock
T72
thanks for the pictures guys. i was hoping not to eliminate my ac lol. but if i have to i guess i have to. i was wondering if anybody know if i could move my ac compressor to the location that they were in the ls1's. it hot here in the south lol. does anybody have any pictures where they are relocated to the other side of the engine. i saw on a v6 camaro that a guy took the exhaust pipe from the "Y" in the pipe to the turbo. how would that work on the v8. i dont know if this will create much lag for the setup or not. but this would allow me to put the turbo where i want it.
Old Jun 4, 2008 | 07:55 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
my old setup.
corvette manifolds flipped upside down. with 304stainless for the rest
http://www.cecoatings.com/images/turbo%20pipes2.jpg
http://www.cecoatings.com/images/Car.../hotside304ss/
Old Jun 4, 2008 | 09:24 PM
bob8703's Avatar
Originally Posted by TPl383
my old setup.
thats awsome! thats the setup im going to use. did that fit perfectly in the engine compartment. did you have to move any componenta around. i actually sent you a pm about you car. i saw it on another site. you wouldnt mind telling me how much this all costed you and what turbo you used would you. i was going to put a t3/t4 turbo on but ive been reading around and it seem that the best might be the t70. any opinions. and what did you do with you coolant overflow? thanks again those pics help a bunch.
Old Jul 6, 2008 | 09:02 PM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
Just about done with mine now and have my a/c on it still too. I have many posts on how I did this all and am going to finish putting in the rest of the setup shortly for what I bought as far as pipe kits and intercooler. I copied chris's set up but built my headers instead of fliping over stock vette ones.All I have left is finishing up the wiring that was on the starter. I have to move it to a junction box and tie in the battery that is now in the spare tire well and then hook it to the starter. Also have to finish the change to code 59 and start tuning. Been a long road but have a lot less than you would think in it all. If you have any questions on it pm me.
Attached Thumbnails post your single turbo set up pics here-turbo-setup-007.jpg   post your single turbo set up pics here-turbo-setup-006.jpg   post your single turbo set up pics here-turbo-setup-003.jpg
Old Jul 6, 2008 | 09:11 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^ Awesome! Only, please take the wrap off bro. Just got my hands on the '86 Z28 in my sig, came w/wrapped Hooker headers, but it also came with see through flanges....
Old Jul 6, 2008 | 09:18 PM
Nasty....!!!!
Old Jul 6, 2008 | 09:22 PM
lt1z350's Avatar
wrap has to stay. too much heat from all the turbo pipes. If you keep it dry it will not eat up the headers. Also the pipes are painted and oven cured which should also help with keeping the rust away. A buddy did the same on his mustang and going on 2 years with no rust problems from the wrap.
Old Jul 10, 2008 | 04:01 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
The engine bay pic was taken pretty much after i got it all together. It is much cleaner now.
Old Jul 31, 2008 | 06:43 PM
83 Crossfire TA's Avatar
Where did you run your down pipe?
Chris (TPI383), did that setup ever get a down pipe?
Old Jul 31, 2008 | 09:49 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I have plans for a 91mm turbo, probably mounted in the general area as most. I just don't know where the hell I'm going to stick the 5" down pipe at. Oh, and I need a buyer for my procharger stuff first too...hint, hint.
Old Aug 1, 2008 | 01:32 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
I use to have a Master Power T-70, until I went WOT one day and a Vaccum line came off and got sucked into the turbo. So I decided to upgrade to a S400 with a 4" downpipe. Almost done with mock up, then I will get everything coated.
Ray
Attached Thumbnails post your single turbo set up pics here-camaro-turbo1.jpg   post your single turbo set up pics here-camaro-turbo2.jpg
Old Aug 1, 2008 | 07:21 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Vaccum line came off and got sucked into the turbo.[/B]
If it's a street car, you should probably put a real air filter before the turbo to avoid compressor/engine damage. Otherwise your setup looks killer. What are the dimensions of your downpipe?
Old Aug 1, 2008 | 08:31 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
Not really a street car, BUT sometimes I can't resist to take it out on the street...... The down pipe starts off at the turbo as 4" round then as it starts bending it is also goes to 4" oval.
Old Aug 2, 2008 | 11:41 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
This is my current personal kit. I also dont use any filter and is a street car.
Attached Thumbnails post your single turbo set up pics here-engine-bay-2-.jpg   post your single turbo set up pics here-engine-bay-2.jpg
Old Aug 2, 2008 | 11:44 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Here is a shot of the car with the front clip on, cruising day.
Old Aug 2, 2008 | 12:22 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
what the **** holy turbo large zomg askjals;dj dude... how big is that turbo!
also it looks like everyone with a turbo is using an HSR set up... woot
Old Aug 3, 2008 | 08:16 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Its a T76. And yes, the HSR is so good to work with and gives more power than the TPI. The only thing I miss about the TPI is the looks, but every time I have to remove an injector I totally forget about it
Old Aug 3, 2008 | 08:39 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Tru... ive had two or 3 TPI set ups in my hand or on parts cars but never got around to swappin em on LOL.... esp after taking the set up off the parts car. (most of the lower manifolds were eroded from coolant anyways)
That turbo looks huge for a t76... Im just getting my HSR megasquirt running. I cant wait to get some boooooosst.
You still doing TT headers?
Old Aug 3, 2008 | 08:45 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Maybe is the ASME air inlet that makes it look larger. Yes I am still making the TT and everything else just like before. Check: www.bermudezcustomdesigns.com
Old Aug 3, 2008 | 11:01 PM
bbs, I've seen your single setup installed with the AC still in the car... what's the biggest down pipe that you know of that's been installed with that setup?
Old Aug 3, 2008 | 11:46 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
ok i see it now... lol big horn cool... im glad you are still doing reg business... i was kinda dreading building headers... my welds are ugly
Old Aug 4, 2008 | 11:50 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Now that you ask, rtkjadam's is the biggest with the 4" oval that he mentioned earlier, but that is without A/C. I do have a 3 1/2" downpipe with cutout (rtkjadams; you should do the same ). With A/C I never had made one or heard of anyone with more than 3" downpipe. The fiber A/C housing on the firewall really makes things tight down there, a 3" downpipe is about 1/2" away from it on the nearest spot.
Old Aug 6, 2008 | 07:44 PM
lt1z350's Avatar
83 crossfire ta you asking me about my down pipe set up???? I have it done and a bunch of pics if needed. Still havent fired the car. Have a few little things left and havent had time to get it running but very soon. So dang hot in Fl right now that it makes working in the garage unbearable especially when doing it all week long for a living.(working on cars).
Old Aug 6, 2008 | 08:10 PM
fun Pain's Avatar
Transmission: 4l80e
My turbo is a HX50W (W for internal wastegated) with a 64mm inducer and 99mm Major, exhaust outlet is 4 5/8, then funneled down to 3 1/2 untill the cutout (where the cat used to be) the out of the cutout into an American thunder stainless cat-back.
Old Aug 7, 2008 | 11:11 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Its a little cleaner now. And i added a tial BOV
Old Aug 7, 2008 | 10:43 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Nice setups guys. I wanna get a turbo project up and going so bad, this just makes me want it more.
Cheers!!
Old Aug 8, 2008 | 06:57 AM
fun Pain's Avatar
Transmission: 4l80e
turboedtpi: are you running code59... if so I think the rest of use could use a look at your bin, just for reference, since you have been dealing with your a little longer then a few of us.
Old Aug 8, 2008 | 10:41 PM
I'd love to see any pics you have (for that matter, the routing that anyone used to get a good size pipe out of the engine bay)...
Old Aug 9, 2008 | 12:40 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
BBS, are you dribbling water into your turbo? If so, ever notice any erosion?
And fun Pain, nitro is not the same as nitrous.
Old Aug 17, 2008 | 04:11 PM
fun Pain's Avatar
Transmission: 4l80e
LOL I agree... well the whole sig pic is inaccurate now for 2 yrs, nothing about the turbo at all.... lol
Old Aug 18, 2008 | 11:15 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
No, are you talking about the tubing pointing towards the inlet of the turbo? If that so, well that is for the gases of the valve covers, but I removed it because some gases would always escape and I ended up smelling them and it tend to leave a trace of oil in my beautifull turbo's intake
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
BADNBLK
Nov 16, 2016 09:12 AM
project89
Sep 24, 2015 06:38 AM
TheExaminer
Aug 26, 2015 04:59 PM
