inline fuse with procharger
Old Jul 7, 2008 | 03:37 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
i purchased my P-1SC used, it didnt come with inline fuse from fuel pump relay to the alternator. what is the stock amp that came with and what should i buy?
thanks...
Old Jul 9, 2008 | 12:10 AM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: inline fuse with procharger
i justed checked i have a D1SC which should not make a differance and mine is a 30 amp fuse
Old Jul 9, 2008 | 11:31 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Most pumps use less than 10 amps at normal fuel pressures. Since the pump is a "boost pump" then it might use up to 15 amps. A 20 - 30 amp fuse would be fine. I would go with a 25 or 30 amp for the extra margin of turn-on current.
Old Jul 10, 2008 | 07:24 AM
BulliTooth's Avatar
Car: 1989 Formula
ya i wasn’t sure cause it was a boost pump...i went with a 30 amp, thanks
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
-=Z28=-
Sep 24, 2015 10:21 AM
gta892000
Sep 16, 2015 12:37 AM
