Thinking about a procharger...
Old Jul 9, 2008 | 05:41 PM
sach712003's Avatar
My goal is 500rwhp and I am trying to get there as economically as possible. Maybe this is not the cheapest way to get there so I am open to any suggestions. I dont want to do nitrous though. I am thinking of going with a gm crate 4 bolt main with the cast crank shortblock. Replace the pistons with some forged speed pros or something simmilar. Then purchasing the Procharger kit for carbs. I will be using AFR 190 heads, 650 holley, LT4 hotcam, LT etc. I am thinking about 7-8 pounds of boost and limiting rpm to
5800 or so. I have done quite a bit of research and I think I sould be ok with the cast crank as long I dont detonate th engine.
Old Jul 10, 2008 | 07:40 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Thinking about a procharger...
it's all in the tuning, i'm runing 12#'s on a cast bottom end 305 block with 9.5:1 compression, with the D1SC Procharger
Old Jul 10, 2008 | 08:10 PM
Tonysz383's Avatar
Car: 88 IROCZ 350
Engine: 355 cu TPI
Transmission: 4L60 w/ 3200 stall
Axle/Gears: 9 bolt W/370 gear
A cast crank is going to be fine for 500 hp. The stock rods will need some ARP bolts. A two bolt main block will also work as long as you don't spin the engine pass 6K rpms, a set of ARP studs will make it better. For a Carb set up will work best with a B&M style supercharger, a procharger works best with fuel injection.
Old Jul 11, 2008 | 12:31 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Why do you think that? That's something I have never heard before and seeing how well over 4 digit horsepower numbers and well into the single digit times have been done with a procharger and a carb, I would tend to disagree.
Old Jul 11, 2008 | 01:40 AM
GrayTA's Avatar
Car: 1989 Trans Am
Engine: 5.7 Carbed 1970 Camaro SS Block
Axle/Gears: 2.73, becoming 3.42 Posi
I am curious about this as well. My eventual goal is 500rwhp as well and I have been planning a Procharger just as SACH has.
PDG
Old Jul 13, 2008 | 12:06 AM
whiteghost7's Avatar
Car: 92rs
I had a gm 350ho cast crate engine at 9psi with a procharger p1sc and it was very reliable and powerful (440 rwhp) with stock everything. Now its getting turboed, we'll see how long it can hold together.
chazman
Aug 28, 2018 03:25 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
midge54
Jan 29, 2017 07:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
