mini blower question
Old Aug 20, 2008 | 01:02 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
I have a mini blower on a sbc it runs fine needs to be fine tuned its a 350 9.5:1 demon 750 vac 2nd backed by a m21. question is this i dont get any boost til 5k then i get my full 5psi what gives? why dont i get it off idle or at lest under 2500?
Jon
Old Aug 20, 2008 | 06:41 AM
Damon's Avatar
Re: mini blower question
That's weird. With the 142 blower on my 383 I get almost full boost the instant the pedal hits the floor and it holds that almost constantly all the way up the rev range. You getting full throttle opening? Maybe the secondary side of your carb isn't opening up until very high RPMs (carb problem)? Is the belt slipping?
Old Aug 21, 2008 | 07:03 PM
jocww's Avatar
I would figure the belt would slip up in teh higher rpm not the lower and its tight .5 in on each side as the instructions say. my demon isnt blower referenced but that shouldnt cause it not to get boost. I dont have a throttle stop on the car and it goes wot.
Old Aug 21, 2008 | 10:38 PM
Drac0nic's Avatar
Hook a vacuum gauge below the carb and see what happens, I think Damon may be on to something tbh. Other than that, what's up with the motor mods wise and are you using the stock pulley? If you don't have enough pulley on the supercharger compared to your engine flow (big cam, aftermarket heads etc. etc.) that can mess with your boost levels. Also, any hissing like the intake leaking?
Old Aug 24, 2008 | 02:36 AM
jocww's Avatar
my vac/boost guage is manifold referenced. I show an amazing 20 in of vac. Mod wise its a mild cam stock heads kb hyper pistons 1.5 rockers. No leaks from the intake even if I did miss it there would/ should bed at least some boost down low and ti having boost up high i would assume that i dont have a leak
Old Aug 28, 2008 | 08:06 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
how many miles are on the blower?
Maybe its just wore out and seals so bad that it cannot move enough air to make boost at the lower rpms...?
Old Sep 1, 2008 | 02:56 AM
jocww's Avatar
like 30 miles
Old Sep 2, 2008 | 08:46 PM
slow84 Z's Avatar
Car: 84-Z28
Engine: nitrous fed 383 SBC
Transmission: turbo 400
Axle/Gears: 9" 3.70 gear
i have a 144 cu. in blower on my 350 . it"s a 8.5 to 1 comp. 350 iI get boost instantly from a little under 3/4 to wfo on the skinny pedal. i am running a 750 double pumper. i would look at your secondarys as the cause for no low rpm boost. it sounds like they are not opening fast enough!
Old Sep 2, 2008 | 11:51 PM
jocww's Avatar
they open up im pretty sure but why would that be the cause of not getting boost at low rpm? vacuum?
Old Sep 3, 2008 | 07:29 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
hard to make boost without any air!
Old Sep 4, 2008 | 01:03 PM
jocww's Avatar
This is true. My secondaries are opening up all the way. I tried a different Demon and its the same.
Old Sep 7, 2008 | 11:12 PM
slow84 Z's Avatar
Car: 84-Z28
sorry i did not respond sooner i have been out of town working do not have a lap top. if u know your secondarys are opening fast i would start looking at your valve train as a posibility. if the lobe seperation is to tight it can cause boost to be blown out the exaust valve as its still open. a good blower cam has 113-114 degrees of lobe seperation. have you called the manufacture?
Old Sep 8, 2008 | 06:00 AM
Damon's Avatar
Let me ask a question..... if you're getting no boost until 5000 and then it jumps straight up, can you FEEL a dramatic change in power at that point (like hitting a nitrous button)? If what you're observing on the gague is correct that's what it should feel like.
If not, I'm suspecting maybe your gague isn't reading correctly. Maybe the needle movement is a little sticky on the boost side.
Also, you are hooking it up to the fitting above the #5 intake runner, right?
Old Sep 8, 2008 | 04:06 PM
jocww's Avatar
Not a dramatic surge but you can feel it. I am not at home so I am not sure if its ont eh number 5 but I am pretty sure it is.
I havent called demon or weiand yet.
Frozer!!!
Jan 19, 2024 04:55 PM
gixxer92
Sep 1, 2015 04:32 PM
soarestransam
Sep 1, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
