Twin Turbo 5.7 Vortec questions..............
Old Aug 27, 2008 | 06:27 PM
dave63080's Avatar
Thanks in advance,
I am building a 5.7 vortec (383 stroker) factory block, heads and cam. The turbochargers have a .63 hot side, .50 cold side with external wastegates and a 750 cfm intercooler. I am installing scat brand crank, connecting rods, dish pistons (8.5 to 1 compression) etc. I am going to purchase a Barry Grant 750 cfm blow thru carb and a MSD box with adjustable retard. I am planning on running 12 psi of boost and might turn it up to 20.
My questions are, have I matched everything up right? I was told the vortec head's combustion chamber might not handle the pressure. How much horsepower can I expect at 12 psi? I have already purchased the turbos and scat kit. I thought I would ask someone with the expertise before I made any more mistakes.
Thank you for any advice, dave63080
Old Aug 27, 2008 | 11:26 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: Twin Turbo 5.7 Vortec questions..............
12 psi should work good with 8.5:1 compression. For 20 psi you may need to drop it a little more. The hardest part of matching everything, and the easiest ot f-up is the cam choice. A good blower grind should be good for you, but I would actually call comp to get a recomendation for an engine like that.
The vortec heads should be good, but to much pressure any head will need to be o-ringed. I thought about something like that with my engine, but i have no idea where to start tuning a push-through carb.
As for horsepower...... to many variables. I got a streetable, N/A vortec 350 at over 400 crank hp. It depends on the entire combination of parts and tuning. I would say if you don't have at least 450 hp at the tires then something is wrong with the setup.
Old Aug 29, 2008 | 06:51 PM
dave63080's Avatar
Thank you for the advice doc221978,
I am still scratching my head with the carb. I am planning on a 750 Barry Grant blow thru but on the other side an 800 would probably leave more room for error? Any input?
Dave63080
Old Aug 30, 2008 | 01:59 PM
doc221978's Avatar
Car: '81 Z-28
I was just reading into it a little.... The 750 should be big enough, but the 800 shouldn't hurt really. I would recommend getting the engine dyno tuned when your done though. Tuning a blow-through setup is hard to do. I personally wouldn't consider trying. Good luck.
Old Aug 30, 2008 | 03:09 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
a 750cfm carb in blow thru is good for 1600 hp easily, you are FORCING air into the engine, typical cfm ratings for carbs are tossed out the window now.
Old Aug 30, 2008 | 09:07 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yup. i would keep it a little smaller so that throttle response isn't sluggish (800cfm would suck for throttle response) i bet a 650cfm carb would do EVERYTHING you'd ever need it to.
Old Aug 31, 2008 | 08:44 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Dave, this is the route that I'm going. The biggest concern with blow-thru applications is fueling. If your planning on 12-psi, possibly 20-psi, then an electric fuel pump is a must....
A 750/800 cfm carburetor is too much for street use, no matter how much you alter it's internals, you'll never seem to get it just right. I would recommend talking to the guys over at The Carb Shop, they are simply the best w/blow-thru applications, hands down....
Here's something to help you sort things out, Click Here....
Old Sep 1, 2008 | 05:58 PM
dave63080's Avatar
I REALLY appreciate the advise gents,
I have an electric fuel pump ready to go. Finding a dyno any where around here is impossible. I think I am going to wing it and see if I can fine tune the engine myself. Maybe impossible but I'll give it a try. I will take your advise and lower the carb cfm's some.
Thanks again, Dave
Old Sep 1, 2008 | 10:03 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Thanks again, Dave
Tuning is a lot easier today than it was years ago. You can pick up a JAW-WBO2 O2 sensor setup complete for under $120. It has an output that connects to a laptop computer so you can see what your AFR is. It makes tuning easier.
If that was my setup I would go with a 650 cfm carb. 750 cfm isn't bad but is up there. Check out the www.theturboforums.com .........lots of boosted rigs with carbs there.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86Firebird86
Dec 26, 2015 07:21 AM
customblackbird
Oct 1, 2015 04:30 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
IROCtometal
Sep 9, 2015 10:01 AM
