4-bolt block needed with turbo?
Old Oct 6, 2008 | 11:25 PM
whitroc's Avatar
Car: 1986 camaro Z28 iroc
Engine: lb9 topend 350short block
Axle/Gears: stock 10 bolt 3:23
Ok, Ive heard people say you dont need a 4bolt block untill you hit 500hp and or 7000 rpm. is this really true? I plan on running about 600rwhp with a mild motor and a single turbo. about a turbonetics 62-1 1inch a/r. or something similer in size. if any of you have parts for sale that might pretain to this disscution let me know.
Old Oct 6, 2008 | 11:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 4-bolt block needed with turbo?
600 RWHP would by no means be a mild motor, and is probably at the level where you'd want an aftermarket block.
Old Oct 6, 2008 | 11:49 PM
whitroc's Avatar
Ive seen guys produce numbers like that with the stock block. But they failed to say if they were using 2 or 4 bolt mains. Plus, when I say mild motor, I mean that besides lower comp pistons, ported heads, and MILD cam, nothing drastic is done
Old Oct 7, 2008 | 02:42 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Just use the 2 bolt, buy good hardware *think main studs here* and balance everything well, you should be ok. At that power level living on the fringe is all about the tune, go lean a few times or get some blow by and you'll be in trouble.
Old Oct 10, 2008 | 12:36 PM
drfrankenstein's Avatar
iv had this conversation with my dad and the neighbors (alot of race cars in my area) and its been explained to me from a friend who owns a performance parts store that the 2bolt blocks are better to start with and just have them splayed, its stronger than a factory 4bolt. a set of splayed caps would run u like between $90-$250 and its just a couple hundred bucks to have a machine shop tap the block and lined bore the new caps for ya.
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
